Just as an FYI, the ring gear is offset differently on a Z32 flexplate than the Q45 flexplate, so there is a chance the starter won't engage.Carl H wrote:you'd have to skim the bell housing down the same ammount as the thickness of the adaptor plate to compensate for the plate, then in theroy the starter should engage the ring gear but the starter will foul out on the z32 bell.
id be pretty concerned if it was a big spacer, but this spacer .25in thick, hardly anything when you think of some of the spacers being used are nearly 2 inches thick...kool-aid54 wrote:elwesso, how reliable are the spacers. I read on another board that you have to be worried about the flywheel possibly not being balanced and while its spinning it might sheer off? I read that you've been doing this for a while and have had no problems. What do you think about that? I would love to find a cheaper alternative to the maxworks plate, its pricey. Also how different is your spacer compared to the maxworks one? Does an individual doing a vh swap still need to have the bell housing on the transmission shaved down like with the maxworks one?
Modified by kool-aid54 at 4:30 AM 8/27/2009
did you go into any more detail on what you had to do? Ive had my starter not engage about 1 out of every 100 cranks.. usually it would just give a nasty noise, then i try it again and its fine..LEMHEAD16 wrote:Shameless plug.
I have one of Wes's plates on my setup and it has been working great. I had to ream the holes of the starter out to get it to engage every time but other than that it works fine.
+1 for Wes
Ok, sweet. I should have some money within the next couple weeks. Let me know if you're going to run some. where do you find those spacers for the flywheel?elwesso wrote:
The benefit to my plate is it allows people to buy a regular MT and simply bolt it on, no modification to the bellhousing required, and if you need to replace your trans, simply get another one and put it on!!!! Literally, once the plate is bolted to the engine, there is no need to EVER remove it.
were refering to me, I swear it wasn't a plug. Their kit is very expensive for a budget build.LEMHEAD16 wrote:Shameless plug.
+1 for Wes
So it kicks a**? Did you have any issues with the build? I'm having trouble trying to figure out how I'm suppose to do the wiring. Any help would be great.LEMHEAD16 wrote:I wasn't referring to you. I was giving Wes a big +1. I know their kit is expensive, Tha'ts why I went with Wes's plate
Oh hell ya. Whats his handle? So I can get a quote. And sorry Wes for the distraction.LEMHEAD16 wrote:Here's how you do the wiring.
Pack up your KA harness and VH harness and your Gauge Cluster. Send it to Carl and wait a couple weeks. Magically it will reappear at your door ready to install with the Gauges all nice and calibrated.
