evildky wrote:well, for the L28ET swap, you can locate a wrecked donor for around $500 take everythign you need and sell of enough parts to py for the parts car, at least this is how I've done ti 3 times, the engine bolts directly in place and even bolts to your transmission, however if you luck out and find a 5 speeed sturbo parts car then even better
the RB20 has less displacement so you's have to work harder to make the same power (yes the RB is mroe efficient but more displacement = mroe power) you then need to by the motor and trans moutn kit form mckiney or fab your own, and have a custome driveshaft made
stick turbo injectors and management max out around 230 whp, HG and headbolts max otu around 30 whp, and the stock internals max otu around 400 whp, the block, crank and rods are good to north of 600 whpkelloggman wrote:cool. how much hp can one get with a l28et stock and how much with upgraded items
l28 for the win easy and cheap plus I just love the l28 motorRare_f8 wrote:
no, actually it's easier to get more power form the L28ET, it has mor edisplacement and a larger turbo, the RB20ET turbo will max out around 200-250 whp max, the turbo ont he L28ET si good to north of 300 whpflinterman2000 wrote:L28 is the way to go. it's easier to get more hp out of the rb, but it dosent feel right in a Z. I'm looking for a 5 speed stick from a l28, any givers?
someone doesn't know how to tune an afmRed-rbz wrote:Iwill choose rb20 over l28 anyday. It just that rb20 is more realible and faster respond.
As someone who owns a Z31 and Z32 turbo you should know the electronics in those cars are vastly superior to the factory 280ZX AFM system. I'm surprised you haven't put a Z31 ECU in your 240Z actually.evildky wrote:someone doesn't know how to tune an afm
the Z31 ecu si much better , the stock eectronic's on the L28 suck, but can bBleach wrote:As someone who owns a Z31 and Z32 turbo you should know the electronics in those cars are vastly superior to the factory 280ZX AFM system. I'm surprised you haven't put a Z31 ECU in your 240Z actually.
effective my 240Z and my Z31 both run megasquirt, which is far superior to the z31 electronic'sBleach wrote:As someone who owns a Z31 and Z32 turbo you should know the electronics in those cars are vastly superior to the factory 280ZX AFM system. I'm surprised you haven't put a Z31 ECU in your 240Z actually.
