rb25drag »
https://forums.nicoclub.com/rb25drag-u76935.html
Sat Jul 19, 2008 4:21 am
Well I was able to go back to the track last night. But what a horrible night. The Weather was great, it cooled down around 75-78 with not too much humidity, Thought for sure the car was going to run good.
I ended up taking All of the Megan coilover suspension out. It will work if your running a mid 8 sec car /12 sec car. But any more power will not allow it to get the weight transfered to the rear wheels.
So last night I tried the combo of Stock rear suspension and My Stock strut with Tein springs on it in the front.
Worked great. Car hooked good last night. But then i was encountering other problems, Every time I would shift it would go down in RPM's and then Drop a cylinder for about 2-5 seconds then pick it back up. The more I ran the car the worse it got, It just started running PIG rich, Boost is fine still 15lbs, But it seems to me like I killed the plugs with my launch control.
Im going to pull them out today and check them, But my theory is the it either spreaded the gap apart with the misfires, Or it has half fouled a few due to the extra fuel in the cylinders when leaving off the launch control.
My last pass last night Full throttle was 10.04 @ 63mph WOT But the Wideband was reading 9.0 LOL PIG RICH.
Possibly a coil issue also. But im looking into it.
