The ULTIMATE 240SX Bible Volume 1
Got questions about your Nissan? We're here to help, and it's FREE!
sstomek
Alright well there is a lot of useful information out there on the internet. Unfortunately a lot of it is scattered all over the place. This is my attempt to try and bring everything to one place. I have separated them into categories to the best of my ability in the time i have heh which is not a lot. Well here it is the 240SX Bible Volume 1 which consists of a collection of DIYs, How Tos, FAQs, Install Guides, and General Info...
240SX Tech Articles
^^^^don't forget that one, it was pointed out to me after i made this post...damn you AZHitman where were you when i needed you most^^^^
Electronics/ECUECU pinout diagrams.REWIRING YOUR IGNITION COILDistributor TimingRemoving speed limiter on 93 KA24DETDIY Ignition Mods for Better Spark Sr20det Ecu Fault Codes SR20DET ECU wiring diagram. FAQ: KA ECU # Glossory A long tutorial for tuning nissan's ECUs How-To: Chip Your ECU with Pictures (KA24E) Desoldering tipsBattery Relocation
Engine/Engine Info SETTING THE BASE TIMING ON THE DOHC PROPERLY How to build a KA24DE How to: S13 Oil pan removal DIY: HOW TO REPLACE YOUR DRIVE BELTS ON S13 / 91-93 240SX SE / KA24DE How-to: Build Your Own Oil Cooler S13 Red Top Vs. S13 Black Top - The differences DOHC Turbo For Dummies 240sx Engine Descriptions 240SX How To: Removing/Replacing your PS pump DIY: ITB's for your KA24DE Basics of engine management SR20DET Installation GuideEngine Knock (Detonation) Sensor Replacement (KA24DE)
Transmission How To: Convert from A/T to M/T How to Swap Your Auto Transmission for a 5-speed Changing transmission fluid / oil on s13 How to install paddle shift on an automatic 240SX 240sx Clutch and Flywheel SwapClutch Swap
Fuel REWIRING YOUR WALBRO 255 FUEL PUMP ON S14's 240sx: Installing a Walbro Fuel Pump 240sx: Replacing Your KA24DE Fuel Injectors DIY: Installing an injector resistor box
Turbo HOW TO NEVER OVERBOOST AGAINBobby's DIY turbo oil feed/return lines install Turbo rebuild DIY
Suspension/Differential/Brakes Changing differential oil/fluid, 92 240sx, synthetic gear oil, open differential The Definitive 300ZX Brake Swap! Advanced Suspension Definitions Rear differential swaps for the 240sx Rexbo’s Guide to the s13 to s14 Front 5-Lug Conversion Rexbo's Guide To Brake Caliper RebuildingABS Removal
Interior Removing the S13 Door Panel Fabric Low-budget seat modification for S13 Re-covering Your S13 Glove Box DIY: Window regulator repair 5$ DIY: Dye That Ugly Carpet!!!!! W/picsCamera Mount
Exterior HOW TO: Repaint Headlight Housing (Black) DIY: Replacing Your Rusted Hatch 240sx Conversions - An Introduction Sleepy Eyes walkthru (VID) 240sx Vented Hood DIY Rust removal, Fiberglassing, and Body Filler DIY: Silvia Foglight Wiring
Factory Service Manuals/Diagrams Factory Service Manuals (FSMs) Your home for factory service manuals Parts Lists / Diagrams / Setting Sheets
HowStuffWorks Articles Howstuffworks "How Manual Transmissions Work" Howstuffworks "How Differentials Work" Howstuffworks "What is the difference between a turbocharger and a supercharger on a car's engine?" Howstuffworks "How Car Engines Work" Howstuffworks "How Clutches Work" Howstuffworks "How Car Computers Work" Howstuffworks "How Fuel Injection Systems Work" Howstuffworks "How Car Suspensions Work" Howstuffworks "How Anti-Lock Brakes Work" Howstuffworks "How Master Cylinders and Combination Valves Work" Howstuffworks "What does it mean when a car has dual overhead cams?" Howstuffworks "How Camshafts Work" Howstuffworks "How Turbochargers Work"
Now obviously people out there will think that there are some links missing to this bible and that is obviously true. That is where you guys come in. If you think that there is a useful link that should be in here the please post it and I will add to it. The bigger this thing is the better.
Oh and to some of the sites you have to be a registered user (and some you even have to have a certain amount of posts like night-stalkers) before you can view the material. I wish that this wasn't the case because information should be readily available but I guess I see where they are coming from.
Well thanks for looking-Tomek
edit: added a few more articles, primarily the 240tech page, some more ecu stuff and a lot of howstuffworks articles. hehe can never get enough of those...
Modified by sstomek at 1:16 AM 7/28/2006
Modified by sstomek at 1:17 AM 7/28/2006
Modified by sstomek at 5:56 PM 7/30/2006
Ummm, that information (99% of it) can all be found right here:
http://www.240sxTech.com
You've gotta remember, 240sx.org was around before 90% of those other sites, and most of that information originated with 240sx.org members.
Certainly if there's something we don't have, point it out and it'll be added.
Oh, and sites that make you register to see information? They SUCK.
Thanks Tomek!
sstomek
AZhitman wrote:Ummm, that information (99% of it) can all be found right here:
Thanks Tomek!
thats why im posting this on the other sites, it may not help much here but it sure will on the other sites. Just trying to spread the information thats all. Thanks for bashin tho
--Tomek
Ah, understood.
Wasn't my intention to bash - My bad, bro!
Feel free to add the link I included.
sstomek
AZhitman wrote:Ah, understood.
heh i over reacted, just that it took me liike 2 hours to get that stuff ready with the html code for the hyperlinks than you pwned my post up real good with that link hehe.
-Tomek
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Thanks for psoting that... Great way for 240 owners to get started!
Tomek - We can ALWAYS use some assistance drafting articles and compiling additional info for 240sxTech.com and NissanTech.com...
Any time you feel like cranking out some goodies, look at the Articles forum to get a feel for it and rock out.
Good to have you aboard bro.
sstomek
some more links added, not too much time now so ill add the rest later...
-Tomek
iMurphy
Car: Red 95 S14 SE Green 95 S14 SE
Thanks a lot for all the information
sstomek
heh, no problem. I'm hoping to get more feedback in terms of links but I think i may have posted in the wrong section or something. Maybe i should try reposting in a different section...
-Tomek
PantherRacer
Car: 1992 Nissan Skyline R32 RB20DET Sedan
sstomek? GREAT compilation
Hitman? how's that vented hood working out for you? create any problems when it rains? or do you just switch to the non-vented hood in that case lol.
vancouverbc
Car: 1991 240sx
batteryfaq.org is a good faq for batteries.
kamikazeee
Car: 1991 240sx
Nice, that helped me a lot, I love the My240 website
Oh yeah.......Mowisz po polsku?
sstomek
czesc kamikazeee! tak mowim po polsku ale nigdy nie bylem w polskiem szkoly to nie pisam po polsku tak dobze. jeszcze uczym sie
See you live in tinley park, i have a friend close by you. did u buy ur 240 with cams and ecu already on? future plans?
-Tomek
kamikazeee
Car: 1991 240sx
what do u mean by cams and ecu allredy on?
What's ur friends name maybe I know him?
sstomek
lmfao, never mind that is based on ur post counnt, the thing below u. hehe im never on nico although it is crazy. his name is maczej.
-Tomek
kamikazeee
Car: 1991 240sx
No I don't think I know him, but maybe my brother does, well good sticky, oh and it;s Maciej
Return to “Nissan Online Mechanic”
