 240sx: changing transmission fluid / oil on s13First  1 2 >  Last
sanioll
240SX SE - Toyota Camry
Washington, DC
7-17-2004
ok, i changed my tranny fluid yesterday, and i tell ya, i had hard time doing it. fill plug is a pain.
anyhow, here are the instructions for people who wants to know!
STUFF YOU NEED:
--1/2 INCH RATCHET
--WRENCH ADJUSTABLE DOES WONDERS* $15
--FLUID PUMP, $8 BUCKS
--TRANNY FLUID, I USED REDLINE MT-90, $8 BUCKS A BOTTLE, YOU NEED THREE OF THOSE. MAKE SURE YOU GOT 75W-90, GL-4!!!!! GL-5 IS BAD FOR S13 TRANNY. IT WILL IT AWAY YOUR SYNCROS.
*if you cant get fill plug off, then gotta fill thru shifter hole, and for that you need a snap ring pliers?? $10 at advance auto parts.
pic see below
Modified by sanioll at 9:48 AM 12/30/2004
How to change transmission fluid, Differential Fluid, Drive Belts, and Seafoam your S13, '91-93 240SX.
sanioll
Washington, DC
7-17-2004
 « Re: changing transmission fluid / oil on s13 (sanioll)
once again make sure you got GL-4 for tranny fluid.
heres the back of redline mt-90
sanioll
Washington, DC
7-17-2004
you use 1/2 inch ratchet on tranny drain plug, and adjustable wrench goes to the fill plug..
now taking out drain plug is easy. DO NOT do it until you get fill plug out, if your fill plug is stuck and you took drain plug out, that means no tranny fluid == YOU ARE SCREWED!!
taking fill plug out is a pain in the ***. i broke two #17 wrenches on it. finally guys at the shop loosen it up for me.
If you can't take fill plug out, that means you gotta fill thru the shifter hole. For instructions on that, do a search on this forum, an you'll find decent instuctions on how to do it.
Oh, dont forget to put a really good pan underneath, because that fluid is very disgusting.
Drive the car for 5-10 miles,(SHIFT ON ALL GEARS!!) so that the gearbox and tranny fluid is warmed up, then get the fill plug loose, and THAN GO AHEAD AND TAKE OUT THE DRAIN PLUG!!
Modified by sanioll at 9:42 PM 1/5/2005
Modified by sanioll at 3:37 AM 8/22/2005
sanioll
Washington, DC
7-17-2004
this is the mess you might expect if you didn't open the air relief on the oil catch pan. trust me, you dont want that sticky tranny fluid on your garage floor.
very sticky fluid feel, even with the rubber gloves on.
Dont let this mess happen to you
sanioll
Washington, DC
7-17-2004
Ok, this is how drain plug looks like, see below. Make sure you clean it good with a cloth or something. it has worn out paticles of tranny attracted to its magnet. Don't lick it!
sanioll
Washington, DC
7-17-2004
1. AFTER DRAIN PLUG IS OUT, PUT THE CAR DOWN, TAKE OUT ALL JACKS EVERYTING. MAKE SURE CAR LEVELED DOWN ALL THE WAY. ALSO MAKE SURE NOT TO CRASH OIL PAN. mINE WAS FINE.
2. LEAVE THE CAR LIKE THAT FOR AT LEAST 20 MINUTES.
3. JACK IT UP, MAKE SURE YOU GOT SAFE SUPPORT
4. PUT DRAIN PLUG BACK ON, MAKE SURE ITS TIGHT ENOUGH, PUT SEALANT ON IT IF YOUWAN.T
5. TAKE OUT LOOSE FILL PLUG (IF YOUDIDNT DO IT EARLIER, YOURE ****ED)
6. TAKE YOUR FLIUD PUMP, DRAW FLUID FROM MT-90 CAN AND PUMP IT IN, THRU FILL HOLE. MAKE SURE THAT YOU CAN STICK FLUID PUMP NOSE IN THAT HOLE, OTHERWISE YOURE ****ED AGAIN.
7. IMPORTANT, IMPORTANT::: if you drained all the fluid outta tranny, now you gonna need 2.4 liters. YES LITERS, not quarts.
8. if you got redline mt90 then its about 2.5 bottles. 2 bottles and half. kabish? no more no less.
9. bigger the pump, less time it'll take ya to do it. with mine. it took me 3 suctions per bottle to empty it.
10. after you put in 2.4 liters for s13 tranny, put FILL PLUG back on,. tighten it, enough but not to the point that you gonna break a wrench next time.
START THE CAR, TAKE IT FOR A DRIVE, AND NOTICE EASY SHIFTING ON COLD AND DECENT WEATHER.
Modified by sanioll at 5:14 AM 6/13/2005
rek916
sacramento CA
10-20-2004
Good stuff man, this thread was very informative! Kudos to you! ^_-
sanioll
Washington, DC
7-17-2004
 « Re: (rek916)
UPDATE:
I had some major leaks with redline mt-90. its bad stuff, run away, run away.
Just kidding, its everything you could wish for in a tranny fluid. No leaks, no problems at all. Since i'm going to a place that will freeze my *** to death, this oil will prove useful. Below 10F temperatures, here I come.
I got a chance to test the car in cold weather too. It was finally somewhat chily in the morning and i got to drive it while the drivetrain is cold.
Car idled for 3-4 minutes, and i drove off.
Well, to my surprise, you may still feel that harsh shifting from 1st to 2nd because the transmission is cold, but overall, it shifts as easy as it could get.
Oh, and also, the sound on the tranny while operating, has decreased a bit. Like I said its awesome.
HIGHLY RECOMMEND IT. GOOD OIL for OUR S13 GEARBOX.
Modified by sanioll at 3:39 AM 8/22/2005
Timeless240
Queens, NY
7-26-2004
I concur. Sticky-icky-icky!
1993 KA Hatchback - some sound, some suspension, some rust. a little power on the way.
Ren
1995 240sx
Philly PA
7-13-2004
where do you get the redline stuffs? I cant find it in autozone. I am in PA area.
sanioll
Washington, DC
7-17-2004
 « Re: (Ren)
advance auto parts, it is $8 bucks a bottle. you need three of them, butwill use 2.5.
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
UPDATE #2:
Finally i'm back from my trip. actually i was back on the 3rd. I took my 240 on a 400 mile journey with ****load of stuff loaded into the trunk and back seats + passenger. very heavy. And when you climb upto mountain with all that stuff, try to floor it, engine sounds like a heavy classic mustang, but no acceleration.
anyhow, update on gear oil. yes, i did have some problems this time. on my way back, i started to smell gear oil inside the car. well, ok, i was speeding a bit, going pas 6k rpm, passing my other buds SUV at 100mph and stuff. gearbox was hot obviously, so inside i started to smell the gear oil. and it stinks.
i'm thinking maybe i put in too much oil, so its just leaking and stuff, but nothing underneath, and no leaks at all.
SO, I GOT BOLDER AND OPENED UP THE SHIFTER, AND HERES WHAT I FOUND.
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
THE RUBBER THAT SITS ON TOP OF THAT ALSO WAS DRENCHED IN GEAR OIL, AND WAS/IS VERY STINKY. WARM IT UP, IT WILL EVAPORATE AND STINK EVEN WORSE.
SINCE I;M BACK, IT DOESN'T STINK AT ALL. I'M ONLY DRIVING 17 MILES AT MOST IN ONE TRIP TO SCHOOL AND BACK, ETC.. SO NO STINKINESS. BESIDES I PUT A TAPE AROUND IT TO PREVENT IT FROM EVAPORATING INTO THE CABIN.
I WONDER WHERE I CAN BUY THAT RUBBER THING REPLACEMENT AND HOW MUCH WILL IT COST?? I JUST DONT WANT TO START A NEW THREAD FOR IT!
accel junky
Rome and Atlanta, Georgia
4-1-2004
Redline.... nice!
1990 Nissan 240SX RB20DET
1993 Supra Hardtop 67mm (1 of 21) 484whp/455wtq on Pump 18psi
hudy
1991 240SX SE Hatch
Cincinnati Ohio
7-10-2003
i got mine from the dealer for like 4 bucks. Cheap enough.
Jeff
sanioll
Washington, DC
7-17-2004
 « Re: (hudy)
$4 bucks. WOW. i'm calling them tomorrow to order. gotta do it, it smells when i drive longer than 40 miles.
What is the actual name of the rubber again??
EDIT: i might take the camera and show how to change the rubber part and what to expect when filling tranny fluid through the shifter hole too. That should make this 100% covered tranny fluid change.
nismo521
1993 240sx hatchback
Augusta GA
12-15-2003
 « Re: (sanioll)
Yeah, mine was torn up pretty good when I pulled out the old shifter to put in my B&M. I would suggest that everyone w/ an S13 open up the shifter and check that thing.
Bluefire
walnut, ca
6-6-2003
 « Re: (nismo521)
IMO it is much easier to do it through the shifter hole. Just unscrew the shiftknob. Pop of the panel around it. Remove 4 10mm bolts holding upper cover on. Fold Lower cover up so you can see underneath. Use some snap ring pliers to pop off the ring and pull the shifter out. Fill and install in reverse order...
-Bluefire
-Bluefire
Moto Man
93 240SX
Victoria BC
10-15-2004
 « Re: (Bluefire)
Can you get the old oil out through the shifter hole as well, using a vacuum pump?
'93 S13
'00 PC35
sanioll
Washington, DC
7-17-2004
 « Re: (Moto Man)
Just open the drain plug under the tranny. It's a female plug, just use....well see instructions above. Why do ten times more work, when most efficient way available?
Modified by sanioll at 5:12 AM 6/13/2005
Bluefire
walnut, ca
6-6-2003
 « Re: (sanioll)
No you still drain from the drain plug, I just don't like dealing with the fill plug, which is almost always a pain in the butt to remove. Apparently you wasted a lot more time getting that fill plug, versus just going through the shifter hole. Not to mention if you don't have a nice pump, filling it with oil can get a bit messy.
-Bluefire
sanioll
Washington, DC
7-17-2004
 « Re: (Bluefire)
I stopped by nissan dealership yesterday and ordered one of those lower shifter boots. Well, Hello, they always charge us here twice or 3x it actually worth. It cost me $8 bucks. thats just unacceptable. i bought fluid pump for $8 bucks. this sucks
they wanted to charge me $650 for a single rear axle last time.(drifting accident, you know.)
looks like i'm going to take more pictures while i change the boot too, and i will show how to take out the shifter too. That should fulfill this DIY to its satisfaction. I like quality stuff, product/work= ELEGANCE!
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
heres another pic w/sticker from dealer. I hate "Victory Nissan" here in Richmond. They just rip you off.
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
UPDATE #3:
My tranny is feeling good, no leaks, nothing. Redline performance is excellent.
Here are the instructions on how to change the lower rubber boot too.
THese instructions also can be used to take out the shifter, to fill the tranny with fliud thru the shifter.
1. Remove the snap on panel around the shifter. Just hold it from the sides and pull up. take out the 4 screws under that holds the leather boot attached to it.
and this is what you will see:
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
2. take out the shift knob by twisting it. how? Brute Force Attack. (mixing it with something else here )
Don't worry, just try your best, its very strong and won't break. Don't be shy to ask for help from your girlfriend. JUST TWIST IT HARD, !@#$.
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
3. after you take out the shift knob and a leather boot, thisis what you left with. see pic below.
Take out those 4 screws and remove the Rubber Boot and that Metal part.
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
4. You lift up the Rubber Boot and Metal part and this is what you'll be left with. MAKE SURE LOWER BOOT IS IN GOOD CONDITION. OTHERWISE GEAR OIL WILL EVAPORATE INTO THE CABIN (best condition) AND YOU GONNA SMELL THE GEAR OIL IN LONGER TRIPS. LIKE 40 MILES OR MORE.
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
5. Your remove the lower boot by cutting those plastic rings(dont know the name) on top and bottom of rubber boot. and you slide the boot up the shifter.
After the Lower Rubber Boot is out, this is what you left with:
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
5. even though this is a write up on how to change your old lower rubber boot, heres a tip for people onhow to take out the shifter.
Use snap ring pliers to take the snap ring that holds shifter on place. Just squeeze it with pliers and pull it out. it will take couple tries, be patient. See pic below, i used these snap ring pliers. ($10 at advance auto parts
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
6. I'm not going to post pics on how to tkae out the shifter, since i'm changing only rubber boot. old one is torn aprart as you see in the pic above.
real problem arose, when i had to put the new rubber boot on. How do you put that rubber on to a stick that is twice thicker than the rubber's hole.
Believe it or not, but i had to use a lubricant. You konw the one used in the bedroom.
It worked perfectly, it i just slide down there. You may use a regular cream too, to slide the rubber thru the shifter down there. see pic below
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
finished result.
Follow reverse order to put it back together.
make sure to put plastic rings or rubber bands on top and bottom part of new Lower Rubber Boot. I simply used rubber bands. put them on tight. you dont want your vehicle to smell like a gear oil inside.
Modified by sanioll at 5:13 AM 1/11/2005
sanioll
Washington, DC
7-17-2004
 « Re: (sanioll)
I'm guessing this DIY doesn't belong to 240sx--general chat forum.
how to move it to appropriate section?
EDIT: FINAL UPDATE; AFTER 8 MONTHS OF USE, NO PROBLEMS AT ALL. SHIFTING IS NORMAL IN ALL WEATHER CONDITIONS, AND NO GEAR OIL ODOURS WHATSOEVER.
Modified by sanioll at 3:51 AM 8/22/2005
TravisD
Ohioville OH
6-8-2004
I found that a 17mm wrench and hammer worked well for the fill plug.
Ultimately, martial arts means expressing one's self. It is very easy for me to be c0cky. I can show you a lot of really fancy movements, but, honestly expressing ones self...heh...that my friend is...very hard to do. - Bruce Lee
ricebike
89 240sx se 5spd 93 Honda Nighthawk 02 Quest
south or central Jerzee NJ
2-15-2003
nice tip, Travis that open end wrench or a big pipe wrench would make quick work on the fill plug...
mods; where are the pix???
~219,xxx & going strong! @ South Jerzee Piggy-Powa!
WTB/WTT: http://forums.nicoclub.com/zerothread?id=199601 &
http://forums.nicoclub.com/zer...08505
andox
240sx
Torrance ca
3-8-2005
where did all the pictures go?
TravisD
Ohioville OH
6-8-2004
 « Re: changing transmission fluid / oil on s13 (andox)
17mm box-end. Won't slip as easy.
ricebike
2-15-2003
werd: a 12-point box end wrench... i had a 6 point only sooo.... <shrugs>
TravisD
Ohioville OH
6-8-2004
I thought "box end" meant the full circle, and "open end" would mean the "c" shaped type that only grips on two sides (which might be more prone to slipping and messing up the bolt head if the thing's on really tight). I'm not trying to nitpick or anything, just wondering if my terminology is correct.
ricebike
2-15-2003
terminology is correct...
but a 12 point box end = a closed square shape that would bite into all 4 sides... get it? (nah, u needed a bigger size box wrench to fit over the square end, which i didn't have... grr )
soo, i had one of these in my dad's toolbox:
i took the largest one, said a few expletives then, took the remnants of a floor lamp: the hollow sectioned pipe to use as a cheater bar on this tool... it werx!!!
as for teh drain plug, i used a torque wrench borrowed from autozone (hehe ) & it came off quickly...
so now, my car has fresh redline GL4 goodness!~
Modified by ricebike at 9:40 PM 9/8/2006
AnotherOne-via
SF CA
2-13-2006
 « Re: (ricebike)
a 3/4in. box wrench also works on the fill plug, if you have it laying around and don't have a 17mm.
Modified by AnotherOne-via at 12:54 PM 9/20/2006
best way to fix a problem is to make sure it doesn't become a problem.
 First  1 2 >  Last
» Return to 240sx Articles
