kaje36
5-8-2004
thats got a s13 exhaust cam rotated to work on the intake, its off by 3 pins on the chain, the dot on the gear should be closer to the top.
and there you can see the cam position.... and a few of my goodies :D
BadMojo
1993 240SX Fasback, 2007 Mazdaspeed 3
Reading PA
2-22-2003
| Quote » | Originally posted by kaje36
and there you can see the cam position.... and a few of my goodies :D | Forgive me if I'm wrong, but the key is that the cam lobes are pointing directly away from each other when cylinder #1 is at TDC. There should really be a sticky with photos, since this keeps coming up. I'd hate to see someone end up with ****ed up valves. BTW, what kind of header is that? It sure is purty.
Stuff for Sale!SPL V2 Tension Rods for S13 Unorthodox Racing Crank Pulley for KA24DE
LiU
Cars
Atlanta
8-6-2002
hey your cams are orange for intake and green for exhaust... same as mine... but every1 told us that green is for intake andorange is for exhaust... an we ended up with bent valves...
DGA
Cars
Vancouver, WA
1-28-2004
Here is a step by step how-to on KA24DE cam install by a very reputable source, Jim Wolf.http://jimwolftechnology.com/w...E.PDF
Truth is what stands the test of experience. - Albert Einstein
E Dogg
Cedar Rapids Iowa
10-1-2003
i just put my cams in like jim wolfs site.. my concern is going by pics like this its easy to get off by 5-8 degrees one each one, plus i swapped 91 cam into an s14 motor , is that the same too?
DGA
Cars
Vancouver, WA
1-28-2004
Yes all 240s are the same. Jim Wolf site is a great tool in doing the whole process. Its the only place that I have seen that gives you the picture of the cam orientation at TDC. The biggest thing still is that you have to line up the colored chain links to the corresponding marks on the cam sprockets, idler gear, and crankshaft.
E Dogg
Cedar Rapids Iowa
10-1-2003
i dont have a clored mark, could this be why my car revs fine but misses when accelerating hard ?
E Dogg
Cedar Rapids Iowa
10-1-2003
is it possible to have my cams 180 degrees off? i have everything lined up perfectly and im having timing issues...
DGA
Cars
Vancouver, WA
1-28-2004
No. Your car would run like shat. Where did you buy your chains from? They all have marks (different colored links) but they can be hard to see sometimes. If it revs fine and idles fine start checking your ignition components, and your fuel delivery.
kaje36
5-8-2004
LiU: I have a s13 exhaust cam as intake and s14 exhast cam as exhaust.. so the colors are a little messed up, and you can tell by the cam condition they are difrent. instead of repining the exhast cam for the intake we rotated the cam gear to compisate BadMojo: its a SR SSchrome manifold with a KA, and T3 flange on it. Aceinhole was the one who figured out it could be done, and both him and I did this in the same weekend, I like his setup a little better, but mine fits the downpipe alot better. SSchrome just released there KA mani that is the same thing. so its not alot cheaper for thoes peaple wanting a bottem mount turbo on there KA
Oh ya.. FYI thats a s13 head and all the rest is s14
E Dogg
Cedar Rapids Iowa
10-1-2003
my fuel is ok and i have spark on all 4 cylnders it was running decent but according to the timing light it was like retarted 40 deg... when i tried to set to stock it wouldnt even start. Other than the running chitty how can i tell if theyre off for sure? i resued my chain b/c it was ok and i had to remove cams only b/c i replaced the head...
DGA
Cars
Vancouver, WA
1-28-2004
If its retarded 40 deg. I am surprised that you are running at all. Try setting your timing while the car is running. Its easier this way. To see if your cams are off you can rotate your engine to #1 cylinder TDC, take off your valve cover and see where the lobes of the intake and exhaust cam are pointing on the #1 cylinder. Both of them should be pointing away from the center of the engine. I will try to dig up some pictures from when I pieced my engine together. I think that I have some good photos of the stripped engine that has its chains and cams in at #1 cylinder TDC.
DGA
Cars
Vancouver, WA
1-28-2004
Actually take a look at kaje 36's head. He has the engine set at TDC on #1 cylinder.
E Dogg
Cedar Rapids Iowa
10-1-2003
right but everytime i spin the crank the cam spin twice, so every other time i spin it they lobes face out then in right?
DGA
Cars
Vancouver, WA
1-28-2004
Um, your cams should turn once for every two crankshaft turns. So if you turn the crankshaft exactly twice you will be where you started out. If both of your #1 cylinder cams are facing in you are on TDC of cylinder #4, and cams on cylinder #4 should be both facing out. Hope that this helps.
E Dogg
Cedar Rapids Iowa
10-1-2003
yeah thanks
E Dogg
Cedar Rapids Iowa
10-1-2003
is there a precise way to check if mine ar elined up properly my car is still missing at idle and jerkin a bit when i let off gas... edit: could a bad knock sensor do this?
Thee 240sx Owner
Racing... And maybe a Gurl if the car breaks down???
Orlando, Florida
4-3-2003
yes
I may not like NICO but I still sport the banner on the car for ya....."My KA beat your SR" lol Haten on NICO NEWBIES since 4/7/03 "Chances are what i'm posting is either true and you don't believe it... or is down right obvious and you are stupid enough to still not believe it... i honestly don't care what your opinion is... if you ask for mine... deal with whats coming... as for anything else... address it to your recycling bin..." -Me
E Dogg
Cedar Rapids Iowa
10-1-2003
it was the cams... roteated a bit whiel tighing bolts:( got her fixed now though, let the moving vlations commence
andrave
assorted
WV or TX
4-7-2003
mother ****er, I put mine in with orange on intake. not right. now I have to redo them. goddamnit.
 I'm back in the saddle again
98s14inaz
89 Nissan 240sx Coupe sr20det
BFE AZ
12-22-2002
| « Re: (LiU) | 7:33 AM 9/18/2004 |
| Quote, originally posted by LiU » | | hey your cams are orange for intake and green for exhaust... same as mine... but every1 told us that green is for intake andorange is for exhaust... an we ended up with bent valves... |
You are right except the cams are reversed on the s14's so be careful, don't ask how I know.
- Oliver 04 Frontier Desert Runner "Dogs Love Trucks" (240 support vehicle) 89 s13 coupe sr20det
klattr1
art, graphic design, my gf, my car
SC and NC
9-28-2002
hey, i wouldnt be too worried about the paint on the cams. the cams really only go in one way with the way they are oriented and how the pins align with chain, etc. i have always had a copy of JWT's instructions beside me for every cam install ive done.
 GT42R powered KA-T http://www.ka-t.org/ryan_k.php
chandler
91 civic hb & 96 S14
charlotte, NC
1-4-2004
hey guys, man I feel like an impatient a55 hat, I took the cams out of my spare head, (s13) and now I dont know whice is intake and which is exhaust one has a 5 and the other is a 2 any help would be greatly appreciated.
"PS I am a black man from Los Angeles so I bear special love for police trust me " Posted by Redtop91
chandler
charlotte, NC
1-4-2004
one also has blue on it and the other it looks like faded green
H.D.HUMPERDINK
'92 240sx
Glenview IL
10-4-2004
I have a question: I know that on push rod motors you have to break the cam in, and I was wondering if you have break in cams on our cars?
chandler
charlotte, NC
1-4-2004
what about the fuel milage issues, does it stay the same daily driving or does it go down? maybe up?
Chezedik
...and then there were three.
1991 Nissan 240sx
Overland Park KS
12-17-2002
Nissan was nice enough to label your cams, if you look very closely. Check each one, they will have I and E engraved in them. That is how you will know.
Check me out, I'm a ricer: "I am going to get a stage two turbo kit, and nitrous, just like I saw on N4S Underground!!!"Stuff for Sale: !!!BUY MY CAR!!!! 1991 240sx KA24DE-t for sale, very nice!
Stock and Performance Parts For Sale FS: KA24DE MAFS, Wheels, MORE! FS: TiAL 38mm, Jacob's i.C.E. Pak Ignition system, Z31 T3/T04b V-trim turbo more
andrave
assorted
WV or TX
4-7-2003
not mine, thats for ****in sure.
initial_d_s14
1995 240sx 1990 RX-7 1991 240sx
2-16-2004
| « Re: (chandler) | 8:58 PM 2/26/2005 |
| Quote, originally posted by chandler » | | hey guys, man I feel like an impatient a55 hat, I took the cams out of my spare head, (s13) and now I dont know whice is intake and which is exhaust one has a 5 and the other is a 2 any help would be greatly appreciated. |
yeah on the S13 cams the intake has a green mark on it and exaust is a orange mark, i think the 2 is exaust, i cant really remember.oh yeah and since i have installed mine, the gas mileage has went down
 1991 Nissan 240sx 1995 Nissan 240sx
jmhalder
base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
Montgomery IL
3-15-2005
how much was your gas mileage effected, is it still aproximatly over 20mpg
initial_d_s14
2-16-2004
| « Re: (jmhalder) | 8:28 PM 3/22/2005 |
| Quote, originally posted by jmhalder » | | how much was your gas mileage effected, is it still aproximatly over 20mpg |
yeha its still over 20mpg, 2 weeks in a row it was 19.xxmpg. now its back up to 23. Id say the average is around 21 city, 26 Hwy
chandler
charlotte, NC
1-4-2004
I looked at my cams, there are no engravings on the cams themselves, the caps on the head have them, but not the cams
Shift__BODOM
1993 240SX Hatch
Giant Rock, Space
10-7-2004
| « Re: (chandler) | 10:08 AM 5/7/2005 |
hmm, i just swapped my old '93 cams into my new '96 motor, and i've run across a few problems. that image is my '96 cams before i attacked them. i dont have an after pic, but i can tell you that the '93 cams don't look exactly like that...the cams at TDC on cyl #1 with the old '93 cams installed don't point exactly outwards like the other ones did, but point slightly more at an upward angle from the center. this is the only way to angle them so that the valves are all closed. i think that with this setup the intake cam is slightly advanced, and the exhaust cam is slightly retarted by a tooth on the cam gears or a few degrees. with the #1 cyl. lobes pointing out like they should be at TDC, the #3 cyl intake valves and #2 cyl exhaust valves are depressed slightly. i wish i had a picture of the cams the way they are now. btw both cam sprockets are stock, non adjustable ones. i just need to confirm that the cams are off timing...and what about those valves being pushed down slightly? is that a problem or should i focus on putting #1 cyl cams at TDC? AAAH! HELP!
| Quote, originally posted by tenkawa_akito » | | chainsaw > rooftop |
Shift__BODOM
1993 240SX Hatch
Giant Rock, Space
10-7-2004
| « Re: (Shift__BODOM) | 12:53 AM 5/8/2005 |
nevermind. the intake sprocket was off by a whole tooth. got it rotated to spec and everything fell into place. go team!
InsanityInc
8-18-2004
| « Re: (Shift__BODOM) | 11:03 AM 6/15/2005 |
Can anyone with an S13 with cams they haven't messed with tell me if the cams point directly away from eachother or not, and also could they tell me how many links (inclusive) are between the little circular marks on the cam sprockets?
Backpressure is never good. Ever.
tryiian
95 blue emerald s14 KADE
Center Point, Bham AL
5-31-2004
| « Re: (InsanityInc) | 12:43 AM 7/18/2005 |
just go back to the top of the thread and check there, you`ll get both answers.
InsanityInc
8-18-2004
| « Re: (Shift__BODOM) | 10:56 AM 7/23/2005 |
| Quote, originally posted by Shift__BODOM » | | hmm, i just swapped my old '93 cams into my new '96 motor, and i've run across a few problems. that image is my '96 cams before i attacked them. i dont have an after pic, but i can tell you that the '93 cams don't look exactly like that... the cams at TDC on cyl #1 with the old '93 cams installed don't point exactly outwards like the other ones did, but point slightly more at an upward angle from the center. this is the only way to angle them so that the valves are all closed. i think that with this setup the intake cam is slightly advanced, and the exhaust cam is slightly retarted by a tooth on the cam gears or a few degrees. with the #1 cyl. lobes pointing out like they should be at TDC, the #3 cyl intake valves and #2 cyl exhaust valves are depressed slightly. i wish i had a picture of the cams the way they are now. btw both cam sprockets are stock, non adjustable ones. i just need to confirm that the cams are off timing...and what about those valves being pushed down slightly? is that a problem or should i focus on putting #1 cyl cams at TDC? AAAH! HELP! |
I think the LCA is just different between the two sets of cams. If compression checks out then you're fine.
s13sr20chris
nissans
newport news virginia
6-10-2003
| « Re: (InsanityInc) | 4:14 PM 8/20/2005 |
IMPORTANTDONT GO BY THE COLOR OF THE PAINT ON THE CAMS i have just confirmed that some s13 ka24de's have orange on the intake and green on the exhaust while some others have it exactly opposite. i know this because i just rebuilt 2 heads side by side. they were both from 91 s13's and they were exact opposites. i even installed them both ways and was stumped as to why the lobes were not pointed the right way. then i just swapped them around and found this out.
http://www.freakedforjesus.com/
InsanityInc
8-18-2004
| « Re: (s13sr20chris) | 2:33 PM 9/21/2005 |
| Quote, originally posted by s13sr20chris » | | IMPORTANT DONT GO BY THE COLOR OF THE PAINT ON THE CAMS i have just confirmed that some s13 ka24de's have orange on the intake and green on the exhaust while some others have it exactly opposite. i know this because i just rebuilt 2 heads side by side. they were both from 91 s13's and they were exact opposites. i even installed them both ways and was stumped as to why the lobes were not pointed the right way. then i just swapped them around and found this out. |
Interesting. If I recall, the cams have a little I and E engraved on them, don't they?
| First 1 2 > Last |
