S13 KA24DE Cam Alignment
Chezedik
Car: 1991 Nissan 240sx
Postby Chezedik » Sun Apr 08, 2007 11:03 am
No, turns out I am good, and found my problem. The cams are in correctly, but the valve shim clearance still is not correct. This explains why my vacuum reading was oscillating. So I am hand grinding them, and clearancing them that way.
neogeoss4
Car: 1991 Nissan 240SX Hatchback Nismo Edition
Rebuilt head, piston rings replaced, hand cleaned injectors...
Postby neogeoss4 » Fri Apr 27, 2007 3:59 am
i got my head rebuilt, piston rings replaced, hand cleaned fuel injectors, we put it all back together me and my boys and we cant manage to stabilize the engine... it cranks but it shakes and wont stay on... well it's been a few days and its always the same response, the timing is adjusted perfectly to jimwolf specs, but when we crank it and try to adjust the distributor timing, the engine is too unstable, we hafto give it a lot of acceleration just in order to keep it running @ 700 RPM... i REALLY need some help ... please
Silly SR20... Turbos are for KA's!
drEameRvaJ
Car: 1997 Nissan 240SX SE
Re: Rebuilt head, piston rings replaced, hand cleaned injectors... (neogeoss4)
Postby drEameRvaJ » Mon May 21, 2007 8:30 pm
http://jimwolftechnology.com/w...E.PDF
Is this article for S13 cams in a S13? Or is it for S13 cams in a S14?
What's the best combo of S13 cam's to put in a KA-T S14 head?
Let me know. THANKS!
oneline180
Car: 93 RMS13, 2006 B15 Sentra, 1995 D21 Hardbody Pickup
Re: (seanman)
Postby oneline180 » Wed May 23, 2007 10:47 pm
seanman wrote:that would probably mess your **** up considering the intake cam is usually earlly to allow intake flow to push out the excess exhaust. is it not possible to look in a chilton for all the cam timing info and what not? and another question, do you have to worry about your pistons slamming into your valves if your timing becomes off?
actually all you have to do is set #1 to TDC and point the cams away from each other. thats how i have had mine for over a year and the thing still pulls strong, no bent valves or nothing. besides, if you think about it... to swap one cam for the other side of the motor and have it run good then it makes sense that the opposite will work as well.
Kaze
Car: Anime/Sports/Poetry/sleep
Postby Kaze » Sat May 26, 2007 2:24 pm
Hey......im so frikin confused LOL......ive searched trust me, read this whole thread....my Intake cam is GREEN and has a small I and the Exhaust is Orange and has a small E (so its no mith...they are engraved dont belive me i will take pics)
I just want to know if runing both Exhaust cams on a 93 would cause any gains?
Please anyone that has done this let me know!
Thanks
93HATCH240
Car: 1993 NISSAN 240SX HATCH
Re: (Kaze)
Postby 93HATCH240 » Mon Jun 18, 2007 6:48 am
I have a 96 ka in my 93 chassis. I have a set of spare s13 cams. I want to use the s13 exhaust cam(248) as an intake cam. All thats needed is to rotate 4 teeth counter clockwise? Correct?
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Re: (kaje36)
Postby rn240sx » Sat Jan 05, 2008 4:44 pm
kaje36 wrote:
thats got a s13 exhaust cam rotated to work on the intake, its off by 3 pins on the chain, the dot on the gear should be closer to the top.
and there you can see the cam position.... and a few of my goodies :D
What happened to the pics..??
Driftnoob
Car: S13 240sx
Postby Driftnoob » Sat Apr 19, 2008 4:25 pm
yeah mines was of by 5 dgr..... and my headers was red hot in 3 mins. !!!!!!!!!!!!!!!
pflicht
Car: 1991 Nissan 240sx - SOLD
2000 Lincoln LS - DEAD
1997 Nissan Maxima - DD
1991 Nissan 240sx - Project
Re: (rn240sx)
Postby pflicht » Tue Jul 15, 2008 11:17 am
rn240sx wrote:What happened to the pics..??
Speckid14
Car: 2002 SE-R Spec V, 1995 240sx, 1993 240sx Coupe
Re: (neogeoss4)
Postby Speckid14 » Thu Sep 11, 2008 12:55 pm
Sorry for the thread revival
neogeoss4 wrote:If you look closely at the Cams, because im stuck doing this job too, mines werent colored so i had to figure out on my own, lucky us when we first installed them wrong and we ran the engine it didnt bend a valve, but if you clean the cams and look closely they are numbered, 1 for intake and 2 for exhaust. also be careful when taking out the cams, it needs to be a rather delicate process.
THIS IS FALSE! I'm going to put a rest to which cam is Intake and which is Exhaust.
vvvv Look at my cam pictures below vvvvThis is my EXHAUST cam which clearly has a 1 right above the giant "E" making the above statement false that the 1 is for and intake.
Now here is 2 pictures of my INTAKE Cam:
This is the other side of the same cam showing a giant I. (Look closely)
As u can see the about quote is false however, there are instances when sometimes the about quote is true making deciding which cam is intake and exhaust a confusing one. Hence why everyone is confused like no other.
The absolute best way to decide which cam is which, should be decided by the dowel pins on the front side of the camshaft, where the cam sprocket is located.
If the dowel pin lines up with the 1st cam lobe it is the INTAKE cam.If the dowel pin does not line up with the 1st lobe it is the EXHAUST cam.Here is the best diagram to go by. (as previously mentioned):
Kudo's to dkdeleon68Hope this helps you guys out!!!Speckid14
f2xphantom
Car: 1992 240sx hatchback (sileighty)
Re: (kaje36)
Postby f2xphantom » Tue Sep 30, 2008 6:12 pm
hey dus anyone know if putting s14 camshafts on my 1992 s13 will change anything like hp or anything? i have both s14 cams....but i dont know if they are worth installing.
rn240sx
09 Ninja 650R
06 Suzuki S40
Re: (f2xphantom)
Postby rn240sx » Wed Oct 01, 2008 4:50 am
f2xphantom wrote:hey dus anyone know if putting s14 camshafts on my 1992 s13 will change anything like hp or anything? i have both s14 cams....but i dont know if they are worth installing.
yes. the S14's use 232 / 232 cams and S13's depending on yr use 240 / 248
da1dj6oy4236
Car: nissan 240sx
Re: (DGA)
Postby da1dj6oy4236 » Mon Oct 13, 2008 1:10 pm
thanks for the website now i kan finally driva ma baby again thnks a whole bunch man u juz saved me from goin wit out my kar for god knos how long thnks again nd b safe 240S ARE DA SHYT
78lilred
Car: 1992 coupe
Postby 78lilred » Wed Feb 04, 2009 7:06 pm
GUYS PLEASE HELP ME!!!!!
Dropped the sprocket when doing an exhaust cam install on the intake side. I really need pictures or someone to tell me exactly how the dots should line up and how the lobes should look with #1 at TDC. So if someone could rehost those pictures that were on the first page that would be nice. With a 248/248 setup will the lobes be pointing at the valve cover mating surface like stock?
Thanks.
Priyank
Car: 1992 Nissan 240sx SE Convertible
Re: (chandler)
Postby Priyank » Fri Feb 27, 2009 4:33 pm
the one with the 5 53F is intake and 2 53F is exhaust. in other words the one with the green mark is intake, and other one is marked with orange which is exhaust
onedumubm24
Car: I have a 1989, a 1990 and 1991 Nissan 240sx.
Re: S13 KA24DE Cam Alignment (240sxOwner)
Postby onedumubm24 » Thu Sep 17, 2009 7:53 pm
well this is slightly relevant to this postim about to tear my head off because my friend decided to hit the rev limiter tooo many times and blew my head gasket and my radiator. anyone wanna give me step by step on the best way to do this? ive never had to mess with my timing so im kinda lost on this
DMan II-40
Car: 1995 240SX SE
Re: (Speckid14)
Postby DMan II-40 » Wed Oct 14, 2009 8:49 am
Speckid14 wrote:Sorry for the thread revival
Tread bump again.
But what year did these cams come from so that way I know the duration?
(I see you have both and S13 and S14)
Speckid4
Car: 1995 240sx
1993 240sx
Postby Speckid4 » Wed Dec 08, 2010 2:15 am
Those are S13 cams in my picture
I use to be Speckid14 FYI. forgot my password lol
