the converted »
https://forums.nicoclub.com/the-converted-u57671.html
Wed Mar 24, 2010 4:35 am
30 +12v in87 +12v output to components85 and 86 are the trigger and ground.
Your fuse values are going to depend on what you are powering, but most relays won't work for over 30 amps. If all your powering is two amp turn on leads, the 3sixty turn on, and an led I can't see you needing more than 5 amps for a fuse, but what does the 4th wire off your fuse block go to?
