MaximA32 »
Wed Mar 17, 2010 8:31 pm
The 3-way catalyst function B1 code is the actual catalytic converter that is part of the exhaust manifold on that particular side. It could be a problem with the y-pipe as I'm 99% sure that those years had issues with them. I'm also pretty sure that there was a TSB out for them as well. The TSB stated to replace the y-pipe assembly and the o2 sensors and the problem would be fixed.
