wining noise from a SR20? HELLP!!!!!!!!!!!!483018
MyNISMO314
Car: 91 SE Coupe w/red top sr20det(currently for sale)
Looked at an SR20DET today that i was planning on buying ive seen it looks clean sounds really clean at idle BUUTTTT!!!...when you start to drive it and after like 5 minutes at idle it starts to make a really whining noise...i really dont know what it could be im just lost on this one...only thing i can come up with is maybe the turbo is going out since its just a stock t25...ill try to go again tomorrow look at it try to come up with a deal with the guy but until then i want some advice on this and ill try to post a video tomorrow if i go so you guys can see and hear of what im talking about. thanks in advance
dre1507
disclaimer: i'm no car expert.
when the powersteering pump on my es300 was just about done for, it started to make a whining sound. maybe you could look into that.
MyNISMO314
dre1507 wrote:disclaimer: i'm no car expert.
yeah we thought that but then we took the power steering belt off and kept doing it sooooo idk
MyNISMO314
xX RB Xx
Car: SE3P, FC3S, FC3C.
Does it do it at idle? Or is it under load during driving conditions.
Need more details to help.
MyNISMO314
xX RB Xx wrote:Does it do it at idle? Or is it under load during driving conditions.
i could of sworn i covered this...after it warms up lets say 5 or so minutes it starts whining...like i said with the power steering belt off so that means power steering pump is not working...this is driving me crazy i cant point nothing out but the turbo maybe going out...i need more insight on this from people who have more experience with sr motors but all the forums are slow on response or people dont want to post...post if you have any ideas at all thanks
Gcustoms
Car: 1992 240sx LE
if your not too worried about your belt. try thisyou say it doesnt whine at idle right? get a penny or something and place it in the throttle plate so that it's above idle grab a can of wd-40 or other type of oil-based lubricant, while its idling spray each pulley one at a time listen to see if the whine stops, if it does then you've found the problem, if it doesnt move onto the next pulley. but don't spray the alternator, idk what would happen but it cant be good.
S14Kouki10
Car: 1997 240sx
its the supercharger.
Hijacker
Car: '92 240sx Convertible
'94 F-150
Could just be a loose belt too.
xX RB Xx
I'm trying to rule things out. It could be a billion things.
Does it do it at idle? Does it does while you driving under load? Or does it during both?
Portugese Bend
Car: 1995 S14, 2003 CT9A
Can you tell if the whine is coming from any particular side?
Note: I had a whine coming from the passenger side of the engine bay. I heard it under light load starting at about 3000 RPM. I heard it most often coming off the freeway. Replaced my alternator, now it's gone.
scotty-2-forty
Car: 1996 Nissan 240SX SE KA24DET
After the car is warmed up, or after driving it and it makes that sound, park the car and have someone gas it a bit with their foot on the brake (putting load on it). Open the hood and check to see where the sound is coming from. Alternators can whine when they are going bad. Have the alternator checked out, and/or perform a voltage check. Turbo bearings can do this too ... any exhaust smoke??? Since you already ruled out belts, it's not the power steering. Is the temperature okay? Check the water pump. Are you certain it's from the front (sounds can echo or carry) ... check the fuel pump too.
Good luck with it; I know first hand this stuff can drive you batty!
MyNISMO314
no its not the belts i said they were off if you have read the post completely you would know...and no its not the supercharger lol
^^scotty - ill try that considering we havent tried that one yet...ill get a video up today
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
moved to SR forum
Hijacker
'94 F-150
Merging with a repeated thread he posted in the SR forum.
MyNISMO314
Hijacker wrote:Merging with a repeated thread he posted in the SR forum.
thanks sorry i posted once and didnt see it so i just posted in here
MyNISMO314
me and a buddy drove it today that owns a SR...it doesnt do it at idle(like the owner said) it only does it when in boost...i asked the guy if we could check the turbo for shaft play and we took the intake off and we checked the turbo out and had shaft play...we compared it to my buddies good running sr and has wayyy more shaft play so we came to conclusion its the turbo going out...anybody got a t28 for sale haha
MyNISMO314
http://www.youtube.com/watch?v=5K_-dT74S2wsounds like this...sound comes from where the turbo is located when you drive the car
