pooping or ripping sounds coming from driver rear side..HELP
Spanky37
Car: 1993 240sx fastback s13
I can mainly feel it when im turning to the right putting pressure on that end.. but i dont know what it would be.. and its not riding smoothly.. feels alittle bumpy or shaky..
PapaSmurf2k3
Site Admin
Maybe a wheel bearing?
Does it make the noise when the car is stopped and you load the suspensions (kinda jump up and down on that wheel)?
allenms240
Car: 1991 Nissan 240SX
Yeah try jacking th ecar up and turning that wheel by hand and see how it sounds. Is it hard to turn?I had a bad wheel bearing on my car before. An easy job assuming you have a press.
Cone Junky
Car: S13 fastback
BMW e46 328i
Spanky37 wrote: pooping or ripping sounds coming from driver rear side..HELP (Spanky37)
Beano/Pepto and a steam cleaner should solve your problems.Sorry, couldn't let that one go.
I would definitely stop driving the car and inspect it. Jack up the rear end and check for any loose parts in the suspension/brakes. If you can actually feel it, it seems dangerous.
Modified by Cone Junky at 1:19 PM 3/9/2010
Spanky37
it has made that noise before even when im stopped.. and it does seem very bumpy from that side..
jona300zx
Car: '95 300ZX N/A
lol pooping.....carry on
Spanky37
i did just jack the car up and found that my tire has like 2 big air bubbles or w/e you call it in it.. maybe the cause of the bumpiness but. thats not the cause of the noise..
allenms240
Blown struts?What kind of suspension is on the car.With the car off jack/stands. Push down on the back (as if your checking stiffness), is it making the noise?
Spanky37
the stock is completely stock let me go check that.. dont think i will hear a noise though.. like i say it will really start happening when i turn to to the right . putting pressure on it
J14cm7
Car: 95 240sx S14 SR20det
New....
Wheel....
Bearing....
Spanky37
you think thats what it is? ive never had to do that.. is the bearing inside of the hub?
allenms240
Yes, but you said it does it when the car is stopped right? And you said it wasn't hard to turn the wheel when it was on a jack, correct? Any noises from pushing down on the back of the caR?
Spanky37
yeah it has happened when im stopped but not always.. and yeah the wheel was easy to turn.. and when i pushed the back of the car down nothing happened
TurboSauce
Car: 2006 G35 coupe, 2018 Mazda CX-9
Quick question, how often do wheel bushings need to be replaced......
cuz this same thing is happening in my 06 chevy.
J14cm7
If you jack up the car and the wheel wobbles its your wheel bearing. the sound when stopped is maybe the weight shifting
Spanky37
well it doesnt really seem to wobble maybe i didnt turn it enough. i mean the tires it self does seem miss shaped but probably becuase their are two huge air bubbles on the inside of the tire doesnt look good.
allenms240
Hmm, it's not rubbing on anything yeah?Make sure all the bolts for everything are tight and torqued.Lug nuts, strut bolts/nuts, caliper bolts. Etc
Spanky37
can the calipers be makign that noise? cause i know that my rear calipers are seized i had to tighten the piston all the way down just to put new brakes on . and my e brake hardly works. like the handle has to be pulled all the way up for it to barely hold..
Cone Junky
Car: S13 fastback
BMW e46 328i
Spanky37 wrote:well it doesnt really seem to wobble maybe i didnt turn it enough. i mean the tires it self does seem miss shaped but probably becuase their are two huge air bubbles on the inside of the tire doesnt look good.
I think you solved the problem
Spanky37
well i bought new used tires so putting them on soon so ill see if the bumpiness goes away.. but the popping noise stilll happens when i turn right .
