MetalFab »
https://forums.nicoclub.com/metalfab-u155170.html
Thu Mar 18, 2010 4:12 pm
Hmm.. lets see.
The spedometer wigs out when it's cold outside, and bounces between 20+/- of my actual speed, thats when it doesn't just top out. The noise it makes is annoying.
The heater fan makes a buzzing noise when it's not running on high, even when it's turned off.
I have 3 cracks in the windshield, left side, that run parallel from the bottom almost completely to the top. Yet it does not leak. (just asking for a fix-it ticket)
The hole that the compression rod mounts to on the front left side is augured out, I think the rear bushing is gone, and the top of the tire tilts inward drastically. I threw half a dozen camber shims in there to get me down the road (I was too afraid to mess with the torsion at the time)
The power steering needs to be refilled every couple of days, I'm suprised the alternator lasted as long as it has, could barely recognize it .
It's never run quite right since someone put bb's and ball bearings in half of the vac lines when "getting it to smog"... vac line delete now underway.
Other than that I love the truck, 4 wheels almost as well as my cherokee.. oh, and when I get the truck at a flex the front end sounds like it's grinding gears.. zzzzz.. sort of like missing a shift.. idk wtf thats about?
Solid axle conversion is on the drawing board.
OH, and the passenger side door is falling off it's hinges, shuts kinda funny, and has previously been rewelded.
Need a smaller steering wheel.. they don't make these things for 6'7" guys. Wtb ex-cab!
Modified by MetalFab at 7:19 PM 3/18/2010
