vh45 6 speed?????
thegifted21
Car: 1989 240sx se coupe 1963 chevy II
yeo whats up nico. maybe a stupid question, may be one to think about or maybe it was already asked and you can point me in the right direction. anyway. im proposing to put a vh45 into my 63 nova(just because i love nissan and it would be totally bad a**) and i want it to be 6 speed obviously by the title. duh. so i was wondering if the 350 touring 6 speed would work or if it would be worth even trying. let me knowthnx
hatedinthemind
Car: S13 Coupe, Subaru Forester
A 300zx 5 speed would work with an adapter plate i think mazworx have a kit or something but if you really want a 6 speed then you probably will need to have a custom made adapter
XJared
Car: 06 Titan, 83 Z, 10 Z
It's definitely possible with a properly made adapter and using the 350Z clutch and flywheel.
car nut
Car: GT500.
XJared wrote:It's definitely possible with a properly made adapter and using the 350Z clutch and flywheel.
It is possible and has been done before IIRC. What's listed above is what you would need.
The reason people use the Z32 trans is because they're stronger (although they do suffer from weak synchros in 2nd and 4th) and they have taller ratios then the 350Z/G35 6 speed. Most of the cars these motors are swapped into have short final drive ratios (4.08), so the extra gear is basically worthless. If I were you, I'd look into a stronger transmission like a T-56. That would be sweet with a VH.
XJared
Do you possibly have a name or link to who did it on the VH? Would like to see that one.
car nut
Car: GT500.
I actually think I saw it right here a few months back. Wasn't much of an actual adapter plate though, the guy basically set up 3 separate pieces of aluminum with different bolt holes to mate the two. Wasn't pretty, but it did work (although I personally don't feel its strong enough without being a solid piece).
EDIT: Here zer...crude
Like I said, it's crude, but he was able to support the full weight of the transmission with it. He said he made it that way because it was cheaper and he doesn't have a machine shop, but I'm sure someone like elwesso would be able to get a better one made.
Modified by car nut at 8:23 PM 2/6/2010
XJared
Aha, I remember that post, but did not realize it was using a Z33 trans. Crude doesn't scratch the surface on that one.
car nut wrote:I actually think I saw it right here a few months back. Wasn't much of an actual adapter plate though, the guy basically set up 3 separate pieces of aluminum with different bolt holes to mate the two. Wasn't pretty, but it did work (although I personally don't feel its strong enough without being a solid piece).
car nut
Car: GT500.
Hahahaha true. I'd still be interested in seeing if it worked in day to day driving though. If I had a taller rear end, I'd definitely want one for my car.
newbissan-tech
Car: 96 vh45 swapped 240sx SOLD, 2011 frontier pro4x SOLD, 08' Altima SOLD, 2006 TITAN, 2012 SUBURBAN FOR THE FAM.
i remember a better one where they used the vh stock auto bellhousing and a t56 with a hydraulic throw out unit that was mounted on the snout of the input shaft front housing! this was a sick conversion! can't remember for the life of me who it was though!
car nut
Car: GT500.
Gotta find that one. The T-56 is a wonderful transmission. Much better ratios/synchros than the Z32 transmission.
maxnix
Car: 1995 Infiniti Q45
1995 Infiniti Q45t
2000 Infiniti Q45
I remember it as a track build for a Z32.
newbissan-tech
check out zmech.net and i know it's not a 6spd but its a tremec tko i think and a 6spd shouldn't be much harder! and zmech is a member also so you might be able to contact him! here are the linkshttp://zmech.net/photos/index....part1 http://zmech.net/photos/index....part2
http://zmech.net/photos/index....lutch
http://zmech.net/photos/index....final
Modified by newbissan-tech at 1:39 AM 3/4/2010
kingkilburn
Car: '93 240SX
Very interesting. I hadn't thought of that.
EMK
Car: 92 s13 Hatch
XJared wrote:Aha, I remember that post, but did not realize it was using a Z33 trans. Crude doesn't scratch the surface on that one.
Yeah that was me and I don't recommend that route. I've decided to weld the bell-housing on since when placing the engine and trans in the car I noticed a gap between the two signaling that the two shifted that's why I pretty much let that post die.
ultrapulse
Car: z32 300zx, Hilux & Datsun utes
Here's mine froma couple of years back, using a t56 box.
newbissan-tech
did your t56 box come out of a production car or was it a summit/jegs model!
ultrapulse
It came out in either a 97 or 98 vette. Think 97 as they went to a comletely different setup from memory..was a while bacvk when I bought it. So yeah just std GM model. The front of the box is off in one of those pics, as I used the input shaft bearing race to centre to the dummy shaft.
