Wheel Size Question
Ke0
Car: Fuga
I own a 06' M35X and was wondering if someone can tell me the widest i can go with the wheels?
fooitm35x
Car: 2007 M35x
OEM rims are 18x8 with +47mm offsetOEM tires are 245-45-18.
Dial that info into wheel/tire calc and play around to see what works for you - http://www.bigcustomwheels.com/rt_specs.jsp
Ke0
Car: Fuga
Okay....20x9.5 fit on the m35x without rubbing?
Ke0
Car: Fuga
Can someone help me. Well will at least tell me if 9.5 in the fronts will rub or not?
george926
Car: M35
Um.. depend on your offset too... i am running 9.5 front and no rubbing
Ke0
Car: Fuga
the wheel size is 20x9.5 offset 35
07sportm35
Car: 2007 Infiniti M35 Sport
Ke0 wrote:the wheel size is 20x9.5 offset 35
Under normal circumstances it should not be a problem. Every wheel is constructed a little different. The biggest issue will be brake calipers. But with that offset I don't think it will be a problem at all.
The wheel will stick out slightly due to the width and offset. I'm running 9.5 inches wide in the front with a +43mm offset. It's pretty darn flush bud.
I would really consider this fact, road noise will go up by about 25-30% over a 8.5 inch wide wheel. If you can go 8.5 inches in the front with a +35mm offset that would be ideal.
If you do run that wheel be sure to get quieter tires.
Best of luck...
skim35
Car: Infiniti M37 Sport
Well I am running 9x20 30offset front and 10x20 rear 35offset. I also have 10mm spacers in the front and 5 mm spacers in the rear and I have JIC VIP coilovers and its lowered about 3inchs all the way around and I'm not rubbing. OH and I have 245 35 in the front 255 35 rear gunna lower it more in the front and get 225 35 streeeech it mike my rears are. hope this helps...
Ke0
Car: Fuga
Thanx for the info guys, helped alot.
cbishun
Car: Q70L
hey skim, by the pictures it shows that the rear sticks out of the wheel area, you said no rubbing but is that all the time over bumps or just cruising low speed flat ground?
I'm looking into getting 22x10 +40 offset, I don't want it sticking out of the sides
azeiler
Car: 2006 Infiniti M35 w/Luxury Package
Skim - I love the look!! Do you have more pics? From what I'm reading around the boards, you should have poor ride quality and loud too. Is that the case? How are the JIC VIP's on comfort? From pics on JIC's website (http://jic-magic.com/ViewProduct1.aspx?ProductID=34), it looks like adjusting the comfort level is simple and can be done within minutes. However, adjusting the height seems like you have to get under the car. Do you have your ride set at one height, or do you change it?
