Billet Grille Question
sc2nr
Car: 2003 Nissan Pathfinder LE, 1998 Saturn SC2
Hey Guys,
Picked up my 2003 Pathfinder LE today, pumped so far. was looking for little things to change, found an old post about Billet Grilles VS Brush gaurds.
I think I am going to do the Billet Grille, my question is why does this...
http://cgi.ebay.ca/Nissan-Path...ae14b
... Not work on an LE model? at least that what the seller says in the product description.
Anyone got insight?
I will be posting pics up on the Newbie intro thread tomorrow when I take pictures in the daylight.
Nick
rydebynite
Car: 2002 Nissan Pathfinder 3.5l V-6
not for LE? He might have been mistaken. I ordered one as well from another company but was not pleased with how the grille actually mounted up with just some zip ties and tie straps so I ended up reselling it!
sc2nr
this is the answer I got from the seller when I questioned him...
"The size is same. but the difference isinstallation.
- manufacturerdriect"
So that might answer why your's didn't fit rydebynite.
I asked if they sold a LE specific part but haven't heard back yet.
Nick
Pwnin O'Brien
There is no difference between the LE and SE models (with respect to the grille area). The mounting should be the same for both models.
sc2nr
Good to know...I couldn't see it being different that is why I questioned it.
Thanks Pwnin!
slickroger
Car: 2001 Nissan Pathfinder
That looks like it should fit for sure but I doubt that the Nissan emblem is actually on the grille most people stick the emblem back on simply because the grille won't sit flush on the original front unless you remove the emblem off of the original grille. I know I did, If you are going this route your going to want to spray your original grille black so it doesn't show through. There used to be a 5 piece set that's what I bought but haven't seen it for awhile might pop up again somewhere.
naladude911
Car: 2001 Infiniti QX4
Damm, that pathy looks sick
sc2nr
slickroger wrote:There used to be a 5 piece set that's what I bought but haven't seen it for awhile might pop up again somewhere.
What all comes with the 5 piece set?
slickroger
My plate hides the 5th piece that I lost in an accident
Modified by slickroger at 3:15 PM 2/8/2010
sc2nr
Ahhh, I will keep my eye out for that other piece.
Thanks
Innovazn
Car: Yellow 1998 Nissan R34 Skyline RB25DET 5 MT - Current
White 2012 Nissan Altima Coupe 3.5SR 6MT - Salvage (T-Boned at left turn)
White 2002 Nissan Pathfinder LE - SOLD (blew the engine)
http://cgi.ebay.com/ebaymotors...9ffaf
found the 5 piece.i been looking around for one as well, wether it fits for LE i dont know yet, im waiting on the sellers reply
Pwnin O'Brien
Innovazn wrote:found the 5 piece.i been looking around for one as well, wether it fits for LE i dont know yet, im waiting on the sellers reply
There's no fitment difference between the LE and SE. The grille will fit on both.
Innovazn
seller stated that you need to do some cutting and grinding off your stock grille. i can see why you need to remove the emblem but to cut and grind some other stuff is beyond me
edit :: yep, just the emblem needs to be removed and maybe a little grinding down on the LE not a big job at all.... ill be getting mine in the next coming week once payroll comes in
Modified by Innovazn at 1:02 PM 2/9/2010
slickroger
I love the grille just be sure to clean it frequently or you will have spots appearing from dead bugs and other debris.
