max. bore diameter on a ca
Discuss topics related to the CA18DE and CA18DET series engines.
lotusCA18DET
hallo all out there, can anybody tell me what the max bore diameter is on a ca18det, my third cylinder is f**ked by my engine builder and I need to put a sleeve in it, I need to drill to 88.5mm in stead of the 83mm standard bore is this okee or a bad idea? (engine builder is paying for this because it is his fault, much cheaper then buying a new short block)thanks, rick
boost_boy
Car: B12 sentra w/built CA18DET, B12 sentra w/fully-built CA18DET, S13 coupe w/ CA18DET, S13 hatch w/CA18DET, 2002 maxima SE
lotusCA18DET wrote:hallo all out there, can anybody tell me what the max bore diameter is on a ca18det, my third cylinder is f**ked by my engine builder and I need to put a sleeve in it, I need to drill to 88.5mm in stead of the 83mm standard bore is this okee or a bad idea? (engine builder is paying for this because it is his fault, much cheaper then buying a new short block)thanks, rick
88.5mm? Man, what are you trying to do? Your max bore diameter is 84mm (safely). I don't care how much you sleeve the block, there's not enough room for 88.5mms of boring. You are in extreme RB26/30 territory with that demand. Make him buy you another block and start from there.
Dee
float_6969
88mm? I don't think there is enough meat in there for that. If there was, the walls would be paper thing. The builder, if he's worth a damn (sounds like he's not) should be able to tell how far out he can bore it to fit a sleeve.
ca18detgabby
Car: 92 Nissan S13 ca18det SOLD
03 Infiniti G35
why does it need to be bored so much? 5MMs is a hell of an over bore.
mbmbmb23
ca18detgabby wrote:why does it need to be bored so much? 5MMs is a hell of an over bore.
Sounds like the sleeve he wants to use has an 88.5 outer diameter and 83mm inner diameter.....2.75mm thick walls on the sleeve?...sounds normal to me.
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Thats what i was thinking. Hopefully its an outer diameter.
lotusCA18DET
yes it is outer diameter, but I have found a new block, he (the builder) is doing al the work for free to make up for his mistake.....thanks for the replies
Return to “CA18DE / CA18DET Forum”
