hi guys i am planning on changing my engine on my skyline which is a drift car, to a better engine,and i cant decide...i have been reading lots of articles on how a 1jz-gte is better than a rb25det...what i am looking for is more hp and more torque..please help me decide guys.thanks
If you are staying under 500 hp I recommend the rb25, the rb26 is much more expensive to achieve less power. And for drifting, you don't need to make more than 500 hp.
It be cheaper for you to up your fuel system, get a bigger turbo and tune your ecu out. Then you can worry about more important things like your suspension, tires...your driving technique.
Now. Let's say... got a rb25, got new forged pistons, up'ed your fuel system, big turbo, and a way to tune it. It will come out much cheaper than a 1jz or rb26 swap, and you would already be ahead with more power.
RB25 has very good power potential. Plus you should look into getting a taller final drive.
I don't know why I didn't say this earlier, but if you have an RB20DET, you can drift just fine with that engine. It's good for quite a bit of power as it is, so you can slide just fine with it.
It would be more cost effective to just build what you have than trying to source another enigne/trans/ECU and what-not.
The RB20 is a good engine. Had one in my Laurel and had plenty of power to slide it if I so desired. Actually, the guy that bought it off of me took it to a drift even the weekend he bought it and did just fine.
I was running about 240ps to the wheels with turbo back exhaust, M's pod filter and .85kg of boost.
I agree. Actually. I seen one go to 400 hp built up.
as of now i am running on a rb20det..pretty powerful engine,but when i do tandems uns ragainst a rb25 or 26 or a well powered sr20det..i feel as if my engine sounds great but lacks power..thats y i decided to go for a engine swap..i feel rb20 det has a limit of 400hp only
Maybe on stock internals. You could build a pretty mean RB20 with some good bottom end parts, head work, bigger turbo and fuel system, and probably still not spend as much to get there as you would with an RB26 or a 1JZ.
The 26 can make stupid power, as does the 1J, quite easily, but it costs more money as the parts for the RB are more expensive. Plus scoring the engine itself is going to be costly.
Figure on stock RB20 bottom end, with upgraded fuel system, larger turbo, FMIC, full turbo back exhaust and decent computer tune, you could get close to 400.
Now, toss in some forged pistons with a slightly higher comp ratio (not to much higher), a head that has been machined properly, cams with gears to adjust timing...you're gonna be sitting nicely around the 500 mark. And 500 is a lot of ponies.
But, as I have said before, if you're drifting, you really don't need all that much power.
Hell, most AE86's barely break the 200hp mark and look at how well they do in pro circuits.
