Haha yeah, as you said before I'm your guinea pig as when it comes to seeing what this tune/setup can handle. It's definitely a good tune, AFR's are fine and timing is right at 20 degrees in boost. 275whp seems to be the safe limit for the 370cc injectors though, the turbo is probably good for around 320. Homeslice said the GTi-R t28 flows a bit more than the s15 t28, I'm going to see if I can get 325 out of it. If I can awesome, if I can't who cares. I'm happy with this setup at 6 psi of boost haha.Razi wrote: Great results Chris!Glad to be running the same tune as you.
Sweeeet That's good enough for me!I just want 250hp for now.Chris28 wrote:275whp seems to be the safe limit for the 370cc injectors though, the turbo is probably good for around 320.
Hey now, I've always said the hybrid T2 flanged turbo's are great for low boost applications. But if you do decide to run more then 10 psi of boost, you'll have a restriction with the T2 flange and you'll be giving up power vs any T3.Chris28 wrote:
So how's that for a t2 flange, WD?
Are you positive timing was at 20 in boost? Hopefully it's more around 16degrees, 20 timing will give you more power+detonation=busted ringland. I've data logged 4cars running around 8-10psi usually it's 16degrees in boost. 14psi about 14degrees. jwt/enthalphy ecu's t25/8/3.4Double check to make sure timing is being retarted in boost or that ka won't live for long. You've maxed out maf,injectors you usually want 80-85% duty cycle. Becareful as that ka is at it limitsChris28 wrote:
Thanks, yeah I know t2 becomes a restriction at higher boost but I'd rather have good response and lower hp than more power with a bit more lag. Fanboy comment: it's easier to drift with more predictable response haha.WDRacing wrote:
Regardless, you're doing good man.
WD
Thanks man. 5 speed is wayyyy better than the slush box, I'd definitely do that before upping the boost as well.biggie wrote:Numbers look very good.
I still have to get ebc on and to the dyno. I'm slow (Vert 5spd swap got in the way).
Its just 2 different cars, just only one side of the garage is good for working on them (more room). So my boosted coupe sits on the other side as a place holder for the Vert's hood on its roof currently. And of course everything that can go wrong on the 5spd swap, has, so far.Chris28 wrote:Thanks man. 5 speed is wayyyy better than the slush box, I'd definitely do that before upping the boost as well.
Yeah, we've had some bad luck with one transmission bolt, pilot bushing, and AT crank 'slug'. But hopefully will be back on the road next weekend (granted its been too cold to drive the Vert anyway).Chris28 wrote:Oh, I see. Well still 5sp > everything else haha. Hope the rest of it goes well, I remember mine was a pain to do.
Nice, I'll definitely look into this. Thanks!GTR PrYdE wrote:Super cheap combo is Evo 560cc top feeds with project silvia fuel rail, and jgs resistors. Should be around 200 total
Yeah, let me upload the logs somewhere so someone can double check them. Timing is right at 20 all in boost, I'm pretty sure I'm reading it right.KFL wrote:Are you positive timing was at 20 in boost? Hopefully it's more around 16degrees, 20 timing will give you more power+detonation=busted ringland. I've data logged 4cars running around 8-10psi usually it's 16degrees in boost. 14psi about 14degrees. jwt/enthalphy ecu's t25/8/3.4Double check to make sure timing is being retarted in boost or that ka won't live for long. You've maxed out maf,injectors you usually want 80-85% duty cycle. Becareful as that ka is at it limits
If its at 20, retard timing asap. you'll lose power unfortunately but you'll still have your motor. If timing was advance prior it will negate the ecu pulling timing. Should at least leave it at 16,14degrees at wot, a built ka with some meth/E85 could pull off 20degrees.Chris28 wrote:
