Transmission identification
Here you'll find topics regarding the Datsun B210, 310, 610, 710, 810, 1200, and lots of other models - All are welcome!
reuger92
Car: datsun
I am trying to figure out what transmission I have with the Datsun 521 I just picked up. The motor and transmission were sitting in the bed of the truck. The transmission has 1720 692 on the top of the transmission case. My chilton book doesn't have that number for any of the transmissions. Does anybody know what those numbers mean?
Papi Chulo
Car: 72' Datsun 510
Take a picture, post it here.
If it is attached to an L series it is probably a F4W63.
reuger92
Car: datsun
do you have any idea what those numbers mean? in my chiltons book they say there is a 720d series, which is a 5 speed. I didn't know if the 1720 692 meant it was a 720 series.
Papi Chulo
Car: 72' Datsun 510
Does it look like this?
reuger92 wrote:do you have any idea what those numbers mean? in my chiltons book they say there is a 720d series, which is a 5 speed. I didn't know if the 1720 692 meant it was a 720 series.
I do not I do know that the 5 speed is 31.5" long and the four is around 26". There are some exceptions, however.
reuger92
Car: datsun
It sure does look similar I'll take a picture tonight and send it back to you but that does look correct. What numbers are on the top of that transmission? Thanks for trying to help me out Papi Chulo
reuger92
Car: datsun
is there anyway you can send me your email papi chulo for some reason i can't get my pictures to post on this web page?
reuger92
Car: datsun
Papi Chulo is there anyway you can send me your email. For some reason I can't get the pictures on the page. I also measured the length of the transmission is 26" long.
Papi Chulo
Car: 72' Datsun 510
Click my user name, it should be in there.
If the engine and transmission are the original then it is a 4speed. The removable bottom pan only came on the 4 speeds if i remember correctly.
reuger92
Car: datsun
The engine is an L16 which i had from my other 521 that I sold, but the transmission came with the other 521 I bought not too long ago. The only reason I got curios is when I started to mount tht transmission to the engine and putting the inspection plate at the bottom and noticed that the holes on the bottom of the transmission are way bigger than the other holes on the other transmission. Also the holes are standard thread instead of metric. But all the holes line up on the transmission.
Papi Chulo
Car: 72' Datsun 510
Someone must have drilled and tapped it, I had to do this to my starter bolt holes. I think the manual says around 15-30 lb ft for transmission to engine bolts, which isn't much, some one probably went a little overboard and turned the threads into mushh.
To post pics.....create an account at http://photobucket.com
upload your pictures
copy the url and paste it in between image tags [img][/img]
Post some pics of your truck
reuger92
Car: datsun
Papi Chulo
Hey I had another question for you? Have you had to replace your motor mount or had to deal with them at all. I am trying to order a new set because the ones I have are the wrong ones for my truck. I found a set on ebay but they don't look right! So I am just curios if you have heard or dealt with this issue.
Papi Chulo
Car: 72' Datsun 510
never on a truck but on a 510, yes
The first time I swapped a motor into a 510 was on a friends car, at night.... and it took foooorreevver. You have to make sure the mounts are on the correct side. Have the mounts attached loosely to the cross-member and sandwich the engine between them. Slowly raise and lower the engine to get everything to line up, then sneak a bolt in. It was a pain, and took us way longer than it should have. We thought we had the wrong mounts too, and took the ones off the old motor and realized we just had them crossed . Silly noobs we were.
Return to “Other Datsun Cars”
