SirSilvia »
https://forums.nicoclub.com/sirsilvia-u39031.html
Thu Dec 17, 2009 4:03 am
Since I love my '89 240sx Coupe so much I decided to build her a younger twin sister. That and I haven't done a build thread yet.Car: 1990 Nissan 240sx CoupeEngine: SOHC KA24ETrans: ManualProblems: It's in pieces
Bought it from a fellow friend and NICO homeboy (yesitisi). After looking at the pics I know someone might think $600 is still pretty steep. It's not really since it was a complete and running car before someone started the tear down, or so I was told, doesn't matter that engine will become a paperweight. Also came with a manual trans too.
:The idea:I want to be able to tear up some serious pavement with it. and I want a solid and reliable ride, while being able to drive it to meets and events. Generally to just roll nasty around town to scare the Honda boys away.
Before I start to blab anymore, pics (click for bigger images)
What am I gonna do what all that junk... inside my trunk.
Tore up from the floor up. Meh, on the plus side, it helps get at the wiring and can put sound deadening on the firewall now even.
Pretty straight body, and that annoying black stripe and body line are already gone.
Fenders already off, so I can do the wire tuck everyone does. Some nasty shock towers, but those are going to get cleaned and reinforced with 1/4 plate steel. I like that it's stripped, saves me hours later on and I can get to tackling the rust faster.
Trunk lid is in good condition and the top half of the car was rattle-canned black. The whole thing is probably going to be black. I'm going for a "yin and yang" theme for the two coupes. One white and mellow, just for cruising and DD, and this one Black and badass to tear up the track.
Loving the black interior, I've longed to have black ever since my other coupe has brown. Those auto seatbelts are hitting ebay ASAP as long as they still work.
Same goes for these s13 seats, buying my other friend's black s14 seats. Carpet looks ok.
Plans?:Body:Restore the entire body, and paint it. MAAAAAAYBE an aero kit, but that's it, thinking it would be hard enough getting around on coils as is. Plus, those of you who have been to Beaverun, knows their road leading to the facility is complete s*** lol. Going to lay sound deadening throughout the cabin. Keeping as much interior as the cage will allow. Anything that cannot get put in will be paneled off and probably carpeted. I don't want to get blinded by the glare of the sound deadening, plus it would look nice.:Engine:"]SR20DET, I know some say its played out but it never gets old for me. Looking at the cost and easy to source parts, I'm going for it. Would love an RB26DETT, but at the price to put one in, I'll never get it running. I have never gave two thoughts about a LSx, just not a fan. Never liked the CA18DET either, dunno why. I want to shoot for a complete rebuild with forged internals. No real need for a bigger intake manifold just yet, but will get a better fuel pump and larger injectors.Turbo... IDK yet. :Trans/Drivetrain:5 speed manual, short shifter, performance clutch. Going for a lightweight 1-piece driveshaft. I'm putting in a 300zx R32 LSD differential and am shimming it to act as a 1.5 way or a 2-way. I don't know just yet, I have the Diff and the two shims, in time, I will decide which to put in. Get the wheels rollin, I have Infinity j30 axles, since the output for the 240sx diff is 6 bolt (3x2 pattern) and the 300zx is 5 bolt. Going to update the wheel bearings at that time too.:Suspension:I'm going to spend around $1k for coils. I want something with a lot of adjustment possibilities. Going to re-do every single bushing on the car and replace any worn parts as needed. Control arms, and A-arms are getting replaced with adjustable ones. Swap s13 tie rods with s14 ones since they're beefier. Stiffer Swaybars. Going to do a bit of chassis strengthening also.:Braking:Would love some Willwood 6-piston calipers, but will probably settle for the 300zx brake upgrade. Also going to re-do the 20year old brake lines, and braided to the calipers.:Wheels:Something decent, probably in 18's, and a cheap rubber since I'll be burning through them. Also will be going 5 lug eventually, starting out, there won't be anything but steelies on it. (those alloys are going to my other coupe):Gauges:The gauges in the car are going to be all matching (hopefully)-Boost-Oil pressure-Trans oil pressure (maybe)-2nd Oil temp for an actual reading, unlike the stock gauge.-Air/Fuel-Volts-Water Temp-fuel pressureI want to keep my vents, and don't really like anything on my A-pillar so going for this.I'll get creative with the rest of the other's placement.:safety:Full track-spec cage, most likely of the through dash variety. Haven't made up my mind on seats yet, that's WAAAY down the road anyway. also a 4 point harness and a snell approved helmet.:Electronics:Anything not needed is getting gutted. Everything most likely getting switched to LEDs for a better look and won't drain the battery if left on. Mainly for efficiency and cut down on the load where not needed. IDK about hatchbacks, but coupes have a problem with the tail lights. They burn/melt and the whole socket needs replaced. My best guess is that they are at the end of the line of all the other possible electronics and the current going through them is a little too high. Might be a little costly but I've done most of my lights in the cluster and dome/map lights, shifter light, ash tray, glove box, etc. I want to swap my signals to LEDs as well, would look retarded otherwise. :Sound System:You ask "why the hell is a radio important in a track car?" It will be legalized and driven on the road. Its not going to be anything special. Probably all 6x9s and a headunit that has a USB port.
I'm not going to be worried about weight with this car, only people with underpowered cars worry about weight. I'm looking for a modest ±300whp without it being pushed.
Let this money pit begin!
:::::::::::::::::::::::::::::::::::::::::::::::::UPDATE 12/24/09:::::::::::::::::::::::::::::::::::::::::::::::::Posted my build on another site for local drifters. And the car's original owner found it and posted some pics he had.
Modified by SirSilvia at 3:01 PM 12/24/2009
