Klits562 »
https://forums.nicoclub.com/klits562-u133972.html
Tue Dec 15, 2009 8:37 pm
same thing happened to me good luck mines a 89 and nissan didnt have the key code on comp. You can check your dash there should be a sticker in there with your key car, if not then you can try and have a lock smith make you a new key from your two pieces(i tried this and it didnt work for me). If neither of those work for you then you need a lock smith to come to you and he will make you a new key from your locks.
I had to use the last option it cost me $70 and $3 dollar for addition keys, i made 3 :PThey will come to your house and stick a blank key in your lock, they wil then turn the key back and forth maybe with a little force. This will make your tumblers etch into the blank, he then grinds into the etches, and repeats till the key works.It takes 10 minutes roughly.
