 SMELLING ANTIFREEZE??First  1 2 >  Last
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Hello...
I'm wondering if anyone has been having the issue of smelling antifreeze in their Murano? It's not real strong and isn't constant, but it is there. There have been some posts about it, but no real conclusions. I don't want to wind up with engine failure down the road. Thanks for any info.
Doug
2009 LE AWD
Timmbo
Armada/QX56/Murano/EX35 Moderator
'08 Nissan Armada LE & '08 Nissan Altima 3.5 SE
Green Bay WI
11-20-2007
 « Re: SMELLING ANTIFREEZE?? (govols0511)
Quote, originally posted by govols0511 »
Hello...
Doug
2009 LE AWD
That is strange, I really have not heard of this happening very often. Since it is under warranty I would call the dealer and have them check things out.
'08 Nissan Armada LE (Timberline) & '08 Nissan Altima 3.5 SE (Dark Slate)
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
 « Re: SMELLING ANTIFREEZE?? (Timmbo)
Thanks for the reply--I had seen here someone else had posted something related to antifreeze, they took it to the dealer after after many visits, it came down to a head gasket issue? I think I'm remembering that right. Anyway, my dealer is of course clueless as they all seem to be unless the issue is obvious. I was just hoping that if it's a common problem, that maybe the solution will be spread throughout the Nissan community.
Doug
Desert Rat
Trucks/Murano Moderator
1998 Frontier 4x4, 2002 Xterra 4x4, 2007 Murano S AWD
Mesa AZ
1-17-2007
Mine is developing this. I looked around and found a hairline crack and a minute leak in the coolant overflow tank that was allowing a small bit of coolant to dribble down onto hot surfaces.
1998 Frontier SAS / 2002 Xterra SAS / 2007 Murano S AWD / 2000 Z28 350Z eater / 2004 Suzuki Intruder VS800
KJSmitty
2009 LE
Dallas TX
9-3-2008
Hello...
Doug
2009 LE AWD
Hi Doug,
I was one of the initial posters of this topic. My wifes 09 LE, purchased in 08, has had the smell since the first week. I have never found nor seen a leak yet the coolant level does drop very slowly over time.
Is your smell more prevalent on the drivers side? This seems to be the case with those that have the leak. A few stated it was the rear head-gasket seeping down onto the transmission.
I too notified my dealership early on yet they could not find anything via sight and a pressure check resulted in no leak down... They said they couldn't smell it of course. JUST make sure you get your complaint documented on a work order! I was a Nissan Tech for many years and I know an antifreeze leak when I smell it. This one is obviously out of sight and the liquid is evaporating prior to ever coming visible or hitting the ground.
Troubling, yet my wife is approaching 20K miles on her 09 and the smell and/or illusive leak doesn't seem to have changed or effected performance. I do believe this will be a larger issue down the road both for customers and Nissan.....
Keep us posted on yours
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
 « Re: SMELLING ANTIFREEZE?? (Desert Rat)
I'll take a look--thanks for the info!
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
 « Re: SMELLING ANTIFREEZE?? (KJSmitty)
Thanks very much for the info--I think your original post was the one that caught my attention. I'll try to get it to the dealer for documentation--it's a pain in the a$% though as it's kind of far away. I too think that it will be an issue down the road. Good luck to you!
Doug
smilygo
2009 Murano, 2004 Scion xA and 2004 BMW R1100S
San Jose CA
10-13-2009
My Muano, 2009 S, purchased in September this year has the same issue. Not every time, but after heavy stop and go drving, I smell anti-freeze. I asked Sarvice manager to check during the initial service at 3750miles. He says his mechanic didn't find any issues. The problem is that it is not all the time. No loss of anti-freeze. Very strange.
riderman
97 Q45 2009 Murano SL
Virginia Beach VA
2-9-2008
My 09 Murano has this issue as well. My Wife works for Nissan and has taken it in twice. The Technicians could smell it, but they could not find a leak. Sometimes when she puls it into the garage, you can smell it pretty strong, but no leaks are obvious. Untill I read this post, I thought our Murano was the only one with this problem.
Rich
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
 « Re: SMELLING ANTIFREEZE?? (riderman)
Thanks for the info...seems like it's somewhat of a prevalent issue. Please let me know if you have any updates and I'll do the same!!
Doug
monoptn
2009 Murano
Clarksville TN
1-17-2010
I've got the same issue on my 09 with 27,000 miles - coolant smell with no obvious leaks. I'm taking it to the dealer in the morning.
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
 « Re: SMELLING ANTIFREEZE?? (monoptn)
Let me know what they say please! Thanks
monoptn
2009 Murano
Clarksville TN
1-17-2010
My wife picked it up, and said they had to order a part. She didn't remember what part it was! It should be in Wednesday/Thursday, so I'll find out when I take it back in.
monoptn
2009 Murano
Clarksville TN
1-17-2010
The dealer pressure tested my Murano, and found the culprit to be a seeping head gasket. It will be covered under warranty, of course.
shrice
greenbelt md
8-4-2009
Quote, originally posted by monoptn »
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
That's great news! This has been bugging me for months now, again, let me know if your fix works. I'm going to take mine to the dealer but it's a bit of a drive and I'd love to have a solution to present to them!
Thanks again
Doug
shrice
greenbelt md
8-4-2009
.................ours too. Slight antifreeze odor after stopping the warmed up engine. No leaks visible, but the odor is there for a short while.
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Just a thought...since this seems to be such a prevalent problem, maybe you could mention to your dealer (after a successful fix) to contact Nissan...and Nissan might be nice enough to put out some kind of memo to all their dealers nation wide??
KJSmitty
2009 LE
Dallas TX
9-3-2008
My educated guess: Thats exactly what Nissan will be trying to avoid. A "prevalent" leaking head gasket could easily turn into a safety recall for their superb V6...
The only good thing would be if it's contained to a specific group of serial numbers and/or lot of bad head-gaskets. It could even be a lot of poorly assembled engines..
Time will tell.
I'd like to know what the process is for getting the aft head removed etc. I wonder if they pull from the top or come in from the bottom after removing the transmission...
Let us know how your dealer does.
Good luck.
72nismo
510
L.A Ca
11-3-2005
I have a 2006 Murano and I also had the antifreeze smell took to dealer and same thing they couldn't find the problem. This was a year ago or so. 'i just recently smelled it again.I will wait and see what "monoptn" comes back with after the repair work is done.
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Any new news on this?? Were they able to fix it?
monoptn
2009 Murano
Clarksville TN
1-17-2010
The car is in the shop for a couple of days. Apparently they have to drop the motor out to change out the head gaskets. I'll probably get the car back Thursday or Friday. I'll give you a full report then.
If you have a Murano under warranty with an antifreeze smell, I'd suggest that you ask the dealer to pressure test the system and look for seepage around the head gaskets.
If you have a Murano out of warranty with an antifreeze smell, I'd say try to get used to the smell of antifreeze : )
monoptn
2009 Murano
Clarksville TN
1-17-2010
Warped cylinder head. Had to order a new one. No Murano for a few more days.
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Wow--seems rather serious. Keep us informed...are you confident that they will have your car back to it's original state? I wonder what the ramifications are of not having this issue addressed?
Doug
roadrunner70
fort lauderdale fl
2-1-2010
I have a 2003 Murano which had the coolant smell. They never did find it. Tht car now has 80,000 miles on it and it runs great. eventually, the coolant smell went away.
I also purchased new, a 2008 3.5 altima coupe and it has the smell and there is a small but noticeable loss of coolant in the overflow tank.
My neighbor's 2007 3.5 altima sedan also has the coolant smell, which I noticed when he stopped in the street to talk with me. I know he hasn't brought it in for service.
I decided to do a search today on the web and found this message board thread. My concern with letting them try and fix it, presuming that the dealer acknowledges that there is something to fix, is that perhaps the old saying leave well enough alone applies here. Especially since this seems to be a wide spread problem and it has not hurt the reliability of my 2003 murano.
What are others saying about this?
Thanks,
RR70
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
 « Re: SMELLING ANTIFREEZE?? (roadrunner70)
Thanks for the info! I'm wondering the same thing about just leaving it alone...if you read the other posts on the subject, one poster has had the issue diagnosed and Nissan is doing major engine work to fix...that scares me a bit. I'm mainly pissed because I have a $40K vehicle that has a defect--this is the 8th Nissan I've owned and the 2nd Murano, and the others have been perfect for the most part so this I believe is an aberration. I'm anxiously awaiting the outcome of the major engine work and hope that the dealer will notify Nissan--that may prompt a wide ranging solution...we'll see.
Doug
2009 LE AWD
riderman
Virginia Beach VA
2-9-2008
Well, had the 09 Murano checked for the third time today. The dealer found the leak this time. It is the head gasket in the back of the engine. 7-9 day's for parts and repair. The mechanic called tech support and I guess they formally aknowledged the issue with our car. It has 11,000 miles.
roadrunner70
fort lauderdale fl
2-1-2010
thanks for following up. when you say the back of the engine, since the engine is mounted transversly, are you speaking of the rear part near the firewall, or the "rear" where it is mounted to the transmission? also, when you get the care repaired, can you please tell us what parts were used.
thanks, rr70
Modified by roadrunner70 at 3:08 PM 2/2/2010
KJSmitty
2009 LE
Dallas TX
9-3-2008
Quote, originally posted by roadrunner70 »
Well, if other Nissan (cars/years) 3.5's are having this issue it sounds to me like Nissan has a potentially large issue here. They will however keep it low key for as long as possible.
I too am hesitant however to have them tear into it....
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
I called Nissan and reported this issue...would be awesome if as many of you as possible would report the same. Maybe we can get some action from Nissan corp??
Doug
roadrunner70
fort lauderdale fl
2-1-2010
... i also post some of this information on another nissan owners web site with message boards. everyone should do the same. rr70
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Where is this site located??
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
riderman
Virginia Beach VA
2-9-2008
[QUOTE=roadrunner70]thanks for following up. when you say the back of the engine, since the engine is mounted transversly, are you speaking of the rear part near the firewall, or the "rear" where it is mounted to the transmission? also, when you get the care repaired, can you please tell us what parts were used.
thanks, rr70
The Nissan mechanic stated that it was leaking coolant on the drivers side rear (near the fire wall) and over the transmission. (2 places). The dealer still hasnt performed repairs, but they provided a loaner car. Someone at the dealer told my wife they are trying to get authorization from Big Nissan to replace the entire engine with a brand new one instead of tearing our engine apart. If true, that would make me feel better than the original engine torn apart to that extent.
Modified by riderman at 9:31 PM 2/9/2010
roadrunner70
fort lauderdale fl
2-1-2010
thanks for keeping us up to date. it sounds like your's was leaking quite a bit, since for mine, the holding tank took 11,000 miles just to drop a inch or so. one other board is nicoclub.com. rr70
monoptn
2009 Murano
Clarksville TN
1-17-2010
Day 19, no Murano yet! After they got the motor back in the tranny wasn't acting right. The gear selector P,N,R,D, etc, would not change from P. (Motor's been back in a couple days, and they've been chasing this problem) They talked to Nissan, Nissan sent a tech out to the shop. They thought it was an electrical connection/computer issue originally, but couldn't fix it. Now we're getting a new transmission.
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Timmbo--you got any pull with Nissan? As you can see, this antifreeze issue is quite prevalent and I think Nissan needs to do something about it or they will lose some dedicated customers. What say you?
Doug Frye
govols0511
2009 Murano LE AWD
Sanford NC
5-31-2009
Sorry to hear this...keep us updated please--hopefully Nissan will do the right thing and address what is becoming an increasingly larger issue.
Doug
riderman
Virginia Beach VA
2-9-2008
Quote, originally posted by riderman »
Well, got the car back today. The dealer did not replace the engine. The wife smelled antifreeze before she drove it home. They told her to "put some miles on it". Well, about 50 miles later, the coolant overflow is about empty and the oil fill cap has this white "frothy" foamy thick goo on the side facing the engine. The paper work we received from the dealer never even mentions a head gasked\head replacement. How can this be? One of the problems we took it in for was a defective remote. That is all the paper work mentions, replacing the remote. My wife saw the engine removed and on the floor, so some kind of repair had to be performed. I hate being lied to or played. GRR.. Now what? I guess I gatta get involved now. She will probably get fired and I'll be stuck with a POS because of my temper.
Modified by riderman at 5:41 PM 2/16/2010
Modified by riderman at 5:51 PM 2/16/2010
roadrunner70
fort lauderdale fl
2-1-2010
don't loose your cool. not worth it. however, they will just have to do the repair again.
i took my altima in today and they could't find any problem, and didn't smell the coolant smelll which is quite prevalent when the car is warmed up.
anyway, now i have it documented. i have another year on the warranty so i will see how things go. i would prefer the car get fixed, but sometimes, as i said above, better to leave things alone.... for now. bt the way, this topic is also being discussed on other boards.
rr70
 First  1 2 >  Last
» Return to Murano Forum
