Won't even crank. I turn the key and get one click.zerepdivad wrote:So it won't even crank is what you're saying or it just cranks and doesn't start?
Don't have a voltmeter to check those things... any other way of doing that?Cone Junky wrote:Make sure you are getting 12V signal to the starter solenoid and check for voltage drop from the battery to the starter.Sounds like a malfunctioning ignition switch, but verify before you throw any (more) parts at it.
No, you can't accurately diagnose an electrical problem without a multimeter. A simple test light would help, but it still can't measure voltage drop or lack of proper amperage.NICONick wrote:
^ x3 on the batteryxX RB Xx wrote:^ x2 on the battery
Im out of town for the day and cannot check on my car, care to provide a picture so i can accurately tap and assess once I get back in town...motoxris wrote:It's probably just the relay. Its located in the passenger side fender near the battery tray and windsheild wiper fluid and all that stuff. Its usually blue. I had the same problem. Try tapping on it to. Some times it gets stuck. I bought a new one then tried tapping on it and now it works. So I have a spare relay for when the old one dies permanently.
Where is this screw you speak of? A pic would be greatly appreciated. Is it far down in the steering c0lumn? Thanks.sx moneypit wrote:The switch is very easy to replace.Drop the covers off the column, remove 1 screw and the switch comes out.
Thanks, I will have to take a look tomorrow. A pic would still be nice if someone has one lying around. Also, where would the best place to be to buy one? Im sure its not a part that Pep Boys or Auto Zone would stock. I know Im being lazy but NICO always knows best.mRodiek wrote:I still have this issue. Ive talked to several different people, shops, mechanics etc and generally if its a starting problem then its one of a couple things (already listed):-starter-starter relay-ignition switch
I have replaced allof these with BRAND NEW parts and still have an issue, I think its because my battery is in the trunk and Im losing power somewhere along the line. But follow the cylinder where you stick the key in and youll see on the left side of the colum that there is a screw holding it in, unscrew it then unplug the other end and replace.
