MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Thu Nov 19, 2009 11:56 pm
Do you know what year I30 those wheels came off of? Or how wide they are?
To my knowledge, no I30 ever had factory tires that narrow on 17'' wheels. Sounds like the previous owner put narrower than stock tires on. The I30 17s had 225s on them from the factory. Which is probably what I would do. 225-50-17 was the original size for the 17'' I30 wheels. Or slightly less tall sidewall with 225-45-17.Only 16'' I30 wheels came with 215s on them (215-55-16).
IF the wheels are wide enough, I would go with 245-45-17s. Probably the most ideal size for the Q with 17'' wheels.
As far as the tire blowing out, I would guess that that had more to do with tire condition than tire size. If you're concerned about avoiding repeats, though, don't buy tires with load ratings below 95 or speed ratings lower than V (unless you're buying winter tires, which can be hard to find with V ratings). But really any 225-17 you find should meet or exceed those criteria.
