i got a question about preload on my tein he's
poshatch
Car: p.o.s. 1990 240sx hatch
so right no i have some tein he's and i have been looking into the effects of preloading, right now i have zero preload on them and i was wondering if i could get any information from somebody with experince in testing different preloads and what not. im consittering adding some preload to change the handling so any info would be great thanks
thank you.
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
What are you adding "preloading" to? Tein springs are just that...springs, there is nothing to adjust????
If you would like to know more about tein springs...call tein.
kc240guy
Car: gold s13 and a maxima
he's preloading springs on a set of coilovers not just lowering springs. depending on how much preload you have it may be real bouncy. that's why I took all the preload off mine. I don't know enough about preload myself to be able to set it right.
Gabes13
Car: rb20det s13
What kind of tein coilovers do you have?Pre-load is just to keep the spring seated during rebound. So you don't need much.
poshatch
ok gonna answer the questions yes they are coilovers not springs
they are tein HE coilovers, sorta like low budget tein drifting coilovers and what not
currently i also have a minimal maybe 30 lbs, not even really preloaded at all, and when i dampen to full stiff it is a bit bouncy yes, stiff yes =]
from what i understand about springs, for the most part 0-roughly 40% takes an increasing amount of weight to compress until there then it is the same amount till i guess full compression
from what i read somewhere adding some preload will make the springs require more weight (or force) to compress because they are previously adding a weight lets say 10% so it would require more force for the second 10%, essentially making them sort of stiffer and since i got a full length hight adjustablility on my coilover i can do whatever preload will benefit the most,
i was just curious as to what people put on their drift set up
my friend says about 3 to 4 turns once snug on front and 2 on the rear
any thoughts??
Gabes13
Car: rb20det s13
The HE springs on your coilovers are linear, meaning, the spring rates don't change during compression or rebound.
SOME pre-load is beneficial as it will keep the spring seated. Too much pre-load will tamper with corner balance, shock life and what not.
One or two turns is enough pre-load. Or what ever it takes to be able to turn the spring SLIGHTLY with your hand but not have any vertical play.
poshatch
forshow thanks maynn
