nice i was worried for you. Thank goodness for the simple fuse fixThunderSaloon wrote:Thanks for the replies!I was not thinking clearly after it happened. I was thinking I did something that would cost a grip to fix, so I couldn't make sense of anything I was reading in the service manual because I was flippin' out. I just wanted to ask everyone here and hope the answer was served to me so I could stop worrying. So it seems that cars made in the last 20 years usually have more than one fuse/relay panel. I've only owned 80's and older cars since now. The next day I realized that power doesn't cut out that quickly from shorting something to ground unless it is fused. So I went through the manual with a sane head and found out about the two other fuse boxes. Checking the fuses was highly suspenseful because I just went at it without finding out which fuse was for the driver info system. The problem was nearly the last fuse in the final panel I checked. So now it is fixed and I'll be getting back to the video interface install! More carefully this time.........
Where are the other 2 fuse boxes located at? I have the same problem.ThunderSaloon wrote: ↑Thu Nov 19, 2009 4:07 pmThanks for the replies!I was not thinking clearly after it happened. I was thinking I did something that would cost a grip to fix, so I couldn't make sense of anything I was reading in the service manual because I was flippin' out. I just wanted to ask everyone here and hope the answer was served to me so I could stop worrying. So it seems that cars made in the last 20 years usually have more than one fuse/relay panel. I've only owned 80's and older cars since now. The next day I realized that power doesn't cut out that quickly from shorting something to ground unless it is fused. So I went through the manual with a sane head and found out about the two other fuse boxes. Checking the fuses was highly suspenseful because I just went at it without finding out which fuse was for the driver info system. The problem was nearly the last fuse in the final panel I checked. So now it is fixed and I'll be getting back to the video interface install! More carefully this time.........
