 Does anyone know whats wrong with my spec v? rough idle...power loss
SDspecV
2003 Sentra SE-R Spec V
League City Tx
11-13-2009
Hello Nico club. I need help. I have had my 03 spec v for about a year now and i love the car...when its runnin good. When I baught the car it had a slightly rough idle but it ran great and it didnt seem like a serious problem. Not too long ago i made the mistake of trying to clean my throttle body and ended up having to replace it...tps(tb). It took me a good while to get the problem fixd and durring that time the idle got worse. Now after the fix my idle still sux, sometimes its just a little high and sometimes it trys to stall out but its always rough. I have a huge power loss and the car makes some stupid buzzing/whining noise through first and second gear. O i have also replaced the MAF sensor like 4 or 5 times. two of which they sent me the wrong one. My car has thrown codes like multiple missfire, and intake air temp sensor high output. when i cleard them they didnt come back. now my car shows no codes. I took it to the dealer and they told me to replace the pcv valve and i did but no good. now the rpm's will jump around(between 1000 and 2000) while coasting to a stop wthout taking it outa gear(just pushing in clutch). Also my obdII says fuel system closed loop. My throttle pos is at 1% at idle...and my intake air temp says around 150 degrees...if any of that helps. I heard it could be something with the current my IAT sensor is sending to the TPS. I also heard it could be my cat. I have an aftermarket intake, header and exhaust.
I have also noticed that this is a common problem with this car and if there is anyone out there that knows what it is or how I can fix it...without spending a fortune at Nissan...then PLEASE let me know.
Thanks
nametakennow
Sentra Moderator
'06 MINI Cooper S
Atlanta GA
8-24-2002
Stock exhaust manifold?
Could be ECU, could be that your engine ate its precat or a butterfly screw. If it's the precat, Nissan owes you an engine.
First and foremost, call a dealer with your VIN handy and have them do a recall check on it.
'06 MINI Cooper S - Chili Red/White, stock
Sold - '01 Sentra SE (SR20DE) w/pp (VLSD, FSTB), a few mods
Get your Nissan/Infiniti's FSM here.
Need parts? Look here!
NEW QR25 forum
spec_v03
2003 Nissan Sentra SE-R Spec-V
York PA
12-15-2009
 « Re: Does anyone know whats wrong with my spec v? rough ... (SDspecV)
IAT sensor is in your MAF so youve already replaced that.
sounds like it could be your fuel pump, there was a TSB posted on them for your year i believe. does it start rough to or just idle?
SDspecV
League City Tx
11-13-2009
 « Re: (nametakennow)
no pre cat...i got a new header. megan racing its not too bad but i think i have a leak somewhere. its driven me crazy. i had my butterfly screws on my last tb and they are still on my new one. I'm pretty sure its not the ecu but i need to find out.
SDspecV
League City Tx
11-13-2009
 « Re: Does anyone know whats wrong with my spec v? rough ... (spec_v03)
Fuel pump sounds like a good bet too...i'll let yall know if any of these things work.
» Return to QR Series
