SDspecV »
https://forums.nicoclub.com/sdspecv-u147545.html
Fri Nov 13, 2009 12:35 pm
Hello Nico club. I need help. I have had my 03 spec v for about a year now and i love the car...when its runnin good. When I baught the car it had a slightly rough idle but it ran great and it didnt seem like a serious problem. Not too long ago i made the mistake of trying to clean my throttle body and ended up having to replace it...tps(tb). It took me a good while to get the problem fixd and durring that time the idle got worse. Now after the fix my idle still sux, sometimes its just a little high and sometimes it trys to stall out but its always rough. I have a huge power loss and the car makes some stupid buzzing/whining noise through first and second gear. O i have also replaced the MAF sensor like 4 or 5 times. two of which they sent me the wrong one. My car has thrown codes like multiple missfire, and intake air temp sensor high output. when i cleard them they didnt come back. now my car shows no codes. I took it to the dealer and they told me to replace the pcv valve and i did but no good. now the rpm's will jump around(between 1000 and 2000) while coasting to a stop wthout taking it outa gear(just pushing in clutch). Also my obdII says fuel system closed loop. My throttle pos is at 1% at idle...and my intake air temp says around 150 degrees...if any of that helps. I heard it could be something with the current my IAT sensor is sending to the TPS. I also heard it could be my cat. I have an aftermarket intake, header and exhaust.
I have also noticed that this is a common problem with this car and if there is anyone out there that knows what it is or how I can fix it...without spending a fortune at Nissan...then PLEASE let me know.Thanks
