KA24DE-T FTW »
https://forums.nicoclub.com/ka24de-t-ftw-u147371.html
Wed Nov 11, 2009 6:33 am
well, i am in the process of going KA-T. my main reason for this is for experience. i am building a JGS style log manifold, that will be topped with a Mitsubishi TD04 turbo, i will be running an external wastegate off of the log.
fuel management will be provided by a FMU, im looking for a very responsive setup, running anywhere from 4-7 psi? i dont plan to upgrade this setup anymore than i have to, because i have other plans when this engine goes. compression was good on all cylinders.
now my questions begin, 1) will the TD04 turbo be too small? 2) also, what ratio should i use for the FMU, 6:1 or 8:1i will be using stock everything, injectors, new pump was put in maybe 8k ago (b4 i thought of going turbo)
im just looking for some insight, im on a pretty tight budget, and most everything that van be fab'd will be done. also, this is primarily an autox car. but does do some DD,i just want a lil more go from the motor.
the TD04 turbo i currently have is a TD04HL-13T, but i have access to plenty of other models, like the 15g, 16t, and 18t's.
