zenkiderek wrote:the reason why i was thinking t28 is on the JGS turbo kit thread, I read the t3 they use is poor quality and my friend has a t28 from an rb20 that he is willing to sell for cheap but he said it's too small for my ka.
also another buddy has a v-afc and says it's the same as the safc II with the addition of vtec control. is this true? he only wants $100.
sorry for all the n00b questions
RB20 came with a T3, I owned 2 R32's and still have one of the turbo's in my garage. That's a great turbo, it has ceramic ball bearings instead of bushings and will last forever if not pushed more then 14psi.
Forget the SAFC, it's crap.
What I would do.
Get the JGS manifold with a T3 flange. Also grab their oil supply/return kit. Yes you can find all the pieces cheaper yourself, but theirs is affordable and works very well. Remember the RB20 is a ball bearing turbo and requires a very small restrictor placed inline between the block and the turbo oil inlet, these are readily available online.
You'll need a custom down pipe made for the RB20 turbo, but that's not very difficult for anyone that's welded longer then 1 month
I'd use 550cc injectors at the very least.
300ZX (N62) MAF or the N60 if you get a really good deal on one.
Rom Tune that matches the injectors and MAF. Figure out what tune you want to go with before purchasing the other stuff, makes it far easier. 550/N62 or 72lb/N62 are common tunes and are available from 3 reliable tuners that I can think of off hand JWT, Enthalpy and EFI Specialists. EFI Spec being the most affordable.
EBay FMIC kit made for your car.
Bosche Bypass Valve.
If you push that turbo using the above setup you'll probably hit 300whp. But it'll make a nice safe no lag 250whp all day for years.
WD
