As of two days ago, i think my rear drums are intermittently locking up upon breaking. When i let the break go they stay locked up. At first i thought it was all the breaks but from two days of minimal driving i am starting to think it is just the rear. If i slowly tap on the gas pedal they will let go and no sounds or resistance is noted when driving. It is only when the car is just about to stop do they kick in early. If i have the car in gear and let the break pedal off sometimes the idle will be enough to disengage them but other times i have to add some gas. I now also noting that when i press down the break pedal i hear a click sound near the shifter, but as far as shifting goes all gears work fine and there is no jerking between shifting. This may be a normal sound, I am now paranoid about the car breaking down so I am focusing in on everything! I know that i checked the front pads recently and they are fine as is the break fluid levels. I have been checking for leaks and none to be found ever! Any smart people out there have any ideas? I am in medical school so hopefully this might be something both easy to fix and cheep! Thanks to all that help!
