Yes?chalmer240sx wrote:... I actually found a leak from the hot pipe to the intercooler, could that be the reason for the weirdness when im driving?
You fixed the hot pipe to intercooler? Look for more they can some times be a pain in the a** to find... Your right a jumped timing chain could cause this too so check your timing. Throttle cable will only cause not to go 100% throttle not really a drive ability problem.chalmer240sx wrote: no boost leaks...
i didnt find anymore boost leaks...i replaced the fuel filter with one off of a tt 300zx so thats not the issue eitherp3tchSR wrote: Yes? You fixed the hot pipe to intercooler? Look for more they can some times be a pain in the a** to find... Your right a jumped timing chain could cause this too so check your timing. Throttle cable will only cause not to go 100% throttle not really a drive ability problem.
Like he said. Also, is it running rich? If so it could be the CTS. Also check your CAS. Checking your ECU for codes is always a good place to start.KG300ZXTT wrote:1. timing2. Maf3. Vacuum leak4. Bad injector5. Knock sensor
Best advice right there...KG300ZXTT wrote:And search the forum for this, there are like a hundred posts on this issue.
