 reving problem
chaosli
89 240sx coupe FTW
newton ma
2-23-2008
  reving problem
well first this is my set up as of right now
rebuilt KAe stock spec internals
-stock injecter
-stock MAF
-T04e garret turbo 60trim
-duel n1 isis cat back
-JGS turbo mani
-Tial 34mm WG
-emisson removel (everything except IAC)
is not a complete build but it is as of now and i do have more part to put in
here is the problem if i full thorttle it, the car wont pass 3000 rpm and start spiting fireballs like a bee R limiter
but if i go slow it will do that just fine it'll redline no prob
i doubt the maf will maxout just with this set up
neverlift
Mad Thrasher
PIGNOSE #19 turbo piggy
sunshinestate
4-24-2006
 « Re: reving problem (chaosli)
I hope you have something to increase teh flow of the fuel injectors, or that is probably your problem, full throttle=boost, afr(on a wideband) should be in the 11:1 maybe a hair leaner.
PIGNOSE SQUAD MEMBER # 19
someone buy my wheels http://forums.nicoclub.com/zer...57581
r.i.p. Dad I miss you
06/14/54~04/18/09
r.i.p. Lee
09/01/89~09/28/06
WDRacing
Porn Crusader
1995 240SX, K5 Blazer
USA
11-25-2002
chaosli
89 240sx coupe FTW
newton ma
2-23-2008
 « Re: reving problem (neverlift)
Quote, originally posted by neverlift »
your probally right i have a aem ems i just need to put it in and set it up as well as bigger injectors that i need to set up
WDRacing
Porn Crusader
USA
11-25-2002
Dude...quit screwing around before you blow your motor. It's probably already damaged. Do a compression test.
You can't just add boost to a car and expect it to work.
neverlift
Mad Thrasher
sunshinestate
4-24-2006
 « Re: reving problem (WDRacing)
Quote, originally posted by WDRacing »
You can't just add boost to a car and expect it to work. Unless you crank the base fuel pressure up into the sky...
altered.
Doya
'95 240sx KA-T
MD
4-2-2009
At least get an FMU
chaosli
89 240sx coupe FTW
newton ma
2-23-2008
 « Re: reving problem (Doya)
i do have a ems
RustspecS13
Online
2 s13's and a 95 maxima
columbus ohio
9-8-2007
Well according to you its not installed.
I have 20 junkyard injectors from rx7's and dsm's, and a rx7 turbo. It doesn't mean my rb20 and ka24e are both turbo'd and making 600WHP.
Install your AEM and get it tuned before you blow your motor.
~Alex
Elblanco- '90 s13 hatch Rust spec s13- RB20DET ran/blown/rebuild->rinse/repeat- the daily driver/drifter
JDM Spartan- '91 s13 hatch VQ35 swap of some sort- the long term build
For sale: SS down pipe for rb20/25. Custom made and has lots of ground clearance.
