moso »
https://forums.nicoclub.com/moso-u137641.html
Wed Nov 04, 2009 3:59 pm
that second plug on the tps is for an automatic. when you changed your tps did you adjust it correctly, if not it wont run right, thay are very sensitive. swapping back the other tps wouldn't work either unless you adjust it as well, you cant just go by the bolt marks, not good enuff.
