Is This Really To Be Expected?!
Mickeydee
Car: Nissan Rogue
As the proud owner of a two week old Rogue, i have generally been very happy with the car, however i'm more than a little concerned with the response of the accelleration.
Living in central PA we have our fair share of hills, and even on some of the mildest ones i feel like breathing a sigh of relief upon reaching the top.
This, together with the feeling of uncertainty in the cvt as to what level of gearing should be adopted lead me to contact my local dealer.
Their reply was that these sensations are normal for this vehicle, and "the car will not run correctly until its done at least 3500 miles, and more likely 5000 miles"
I have read a few of the "cvt" posts on this site, but wonder if someone has some feedback as to whether this 2.5 engine will ever behave better than a substantialy smaller one?
wifes rogue
Car: Nissan Rogue 2009 S AWD
Hey MickeyDee,I took a drive from Ontario to Florida, with the Rogue full and 2 bikes hanging off the back end. I did feel a slight delay, its like the CVT has to load itself. But something that I did during the hills section on the trip, press a little harder at the start of the hill to get the RPM's higher so it reacts sooner and thus having a better feel of the power the Rogue has.Getting up the hills didn't have a problem once I started doing that.Enjoy the Rogue.
kerrton
Car: 2008 Nissan Rogue SL FWD Gotham Gray
What's the problem Mickey? You haven't really defined what the issue is, I find the Rogue to have CRAZY power and acceleration for a 4 cylinder in a vehicle of this size. It kicks the crap out of the RAV4 4-cylinder and the CRV 4.
I'm Very happy with the performance of this vehicle, but maybe once you explain what the problem is we can try to help you out. (And the other question I have is, Did you test drive this vehicle before buying it??? If you're so unhappy with how it drives why in the world would you buy it? I guarantee most on here will say they're quite happy with it).
Mickeydee
Car: Nissan Rogue
thanks for the replies.....
"crazy power and acceleration" is certainly not a phrase that currently i would describe my Rogue to have....Dont get me wrong, i love the car and was simply trying to acertain if the sluggishness that i'm experiencing is a trait expected in the running in period.
the car is a smooth ride on the highways, and sometimes without realising i can be going faster than i realised. My concern is about responsiveness when the pedal is dropped, and the fact that when climbing a hill it stays at the same point in the gearing when accelerating, therefore causing the vehicle to slow considerably (appologies if i didnt explain that well).
As for a test drive...yes we test drove a different vehicle at the dealers which had a few miles on it. The route we took was a reletively flat one. and i didnt notice the issue.
As a sidenote, it appears that the issue is more significant when the engine has travelled some miles, than when its driven cold
takeshi
Car: 2008 Nissan Rogue SL AWD
I've never noticed such problems. Though when I don't agree with the CVT I have paddle shifters.
harryg
Car: 2009 Nissan Rogue SL AWD
I think this "lag" he's experiencing is the CVT trying to find the best "gear" for the best fuel efficiency, remember the main reason a CVT was used because they say it helps with fuel efficiency
also remember that the ECU "learns" your driving habits and therefore performs in that way...so if you drive with a heavy right foot then it will learn that and be prepared with faster "gear ratios" if u drive conservatively then it will go for the higher MPG
most likely the ECU has learned that u drive coneservatively(especially since u mention the breakin period)
philipa_240sx
harryg wrote:also remember that the ECU "learns" your driving habits and therefore performs in that way...
I have not been able to determine if the CVT computer has any 'self learning' capability. The manual does not show any or how to reset it if required.
I think the other comments are valid. ie. The CVT tries to obtain the best fuel efficiency under most conditions by running the highest 'gear' it can. Sometimes it feels sluggish as a result For a roughly 3400lb vehicle equipped with a high torque (at low rpm) 2.5L 4cyl, the Rogue does well. It's surely not a V-6 or V-8, but it doesn't consume gas like one either.
My suggestions? Try the following for those really steep hills:
If you have the paddle shift option: Select a lower gear for climbing hills.If you don't: Use the overdrive lock or low gear.
Finally,
The engine will not produce the best power or fuel efficiency until fully broken in. This can take up to 4000mi (6,400km). Give time for your vehicle to break in... you will surely notice a difference.
Pescakl1
Iridium Graphite
philipa_240sx wrote:My suggestions? Try the following for those really steep hills:
If you have the paddle shift option, you can use Philip advice either in City or on Highway, but if you don't have it like me, use only Philip advice in City or you will have a big rpm surge at high speed (with may be a slow down if you hit the limiter) and you may not like it (rough ride).At highway speed, you'd better use wife's rogue advice and anticipate the climb by gaining some speed and rev before.
My wife used the Rogue last week and was really impressed with the power of the engine and the brakes... but she used way more fuel than me when I took my car back on Sunday (between 2 and 2.5 LHK, that is not a so small difference).So yes, you can have a lot of fun with this car (and she has): it is light compare to competition with a impressive torquey and powerful engine, but you will have to refuel more often.With PA hills, you may have to compromise your fuel economy to get going, like with any other cars you may own.
kerrton
I wouldn't recommend using the O/D off button or "Low" gear for those times when you really want to get good performance out of the engine.
I'd use the gas peddle.
If you want lower gearing and hence more power at any given moment, just step down on the throttle and the CVT will very quickly and smoothly select a low gearing and you'll feel yourself rocket forward. It's the simple, you don't need to take your eyes off the road, and it works. Problem solved.
jmcavalieri
Car: 2008 Nissan Rogue AWD SL
I usually plan ahead for hills by accelerating as I'm coming to the incline. However, if I haven't, I use my paddle shifters to lower the gear to 5 and it's much more responsive to climbing the hill.
IdaCrue
I have never noticed a lack of power going up mountain passes in my Rogue. I have been over Teton Pass in Wyoming several times, and was impressed with the Rogue's ability to run up the road (climbs from 6100 feet to 8500 feet in elevation in about 5 miles at a 10% grade). I love how the Rogue just smoothly ramps up the RPM without the constant downshifting and upshifting I had with previous vehicles equipped with automatic transmissions. The CVT did take a little getting used to, but now I enjoy driving with it.
Couz
I've had the Rogue for 6 months and there's definitely things to get used to concerning the CVT.
If your used to a regular automatic transmission you'll definitely feel its different as you don't feel that kick when you press on the gas...the CVT gradually picks up the gear without that sensation, so you may feel like its less power when in reality its just a smoother transition from gear to gear.
Some people like to feel that kick that rocks you from back to forth because its a feel of acceleration.
The CVT doesn't offer that feel which again some may prefer as its smoother.
So when going up a hill it may feel that much less powerful when in reality it is responding to acceleration properly....what I'm saying is its more of a feel than performance you're probably experiencing.
That's how I felt....the car was performing fine, just the feelings, like on occasion you get a bit of a surge from a stop (Torque Converter engage or disengage while stopping at a signal or starting at it), the vibrations, the acceleration etc...
philipa_240sx
Couz wrote:If your used to a regular automatic transmission you'll definitely feel its different as you don't feel that kick when you press on the gas...the CVT gradually picks up the gear without that sensation, so you may feel like its less power when in reality its just a smoother transition from gear to gear.
That is probably the biggest issues to driving a CVT... our brain 'thinks' we are not traveling as fast because there is no correlation to engine noise, 'shift shock' and speed.
Nissan actually did a lot of reprogramming of the CVT to get a more 'natural' feeling while still retaining it's benefits. Things like ramping engine rpm up slightly while accelerating and the simulated 'downshift' shock when you press hard to accelerate.
Couz
Yup, that was my initial reaction to the CVT....I'm not giving anyone any kind of technical info.
This is all my personal experience with the CVT so far.
And like Philip said its more of a brain thing than mechanical thing....you expect certain mechanical reactions but when they don't occur you may feel its mechanical problem.
at first When I would accelerate I had to look at the RPM and speedometer to make sure I was accelerating because the feel was so minimal, it felt like there was no power.
Its the same thing as getting used to the infamous CVT vibration, it bothers the hell out of people at first because it doesn't feel right...but your brain gets used to it.
Return to “Rogue Forum”
