audtatious »
https://forums.nicoclub.com/audtatious-u2438.html
Sat Nov 07, 2009 1:09 pm
Woofer issues are troubleshot via:
1. Check 15A fuse [No. 67, located in fuse block (J/B). Verify battery positive voltage is present at terminal 48 of woofer.2. Check harness continuity between audio unit terminal 12 and woofer terminal 45.3. Check harness continuity between woofer terminal 47 and ground.4. Check the output circuits to woofer from speaker amp.
If it is the passive crossover component then take it apart and check the pieces. It's either a resistor or a resistor/coil combination.
