Patarach wrote:
Wouldn't it be so much easier to just hook up pcv in from of the turbo behind the maf, all pcv recirculation is used for is to reduce emissions anyways.
And I ran 7psi on a t3 60 trim with 5 degrees of retard and a 8:1 fmu for almost 2 years on a stock kade with 130xxx miles, no engine problems what so ever that were boost related. Just make sure you back off the timing enough, and the fmu works great.
not true, proper crank evac can gain power.
see you already know what to do not sure how top feeds hold up to the pressure of an fmu, however I would run a 5:1 and get an adjustable fpr to "fine tune" with a wideband. I have a 7:1 installed and it runs a bit rich still.
IF you go fmu get a btm and leave timing stock(boost timing master) this lets you retard only on boost and is adjustable in cabin. Let wd chime in.. An fmu and btm is great to about 8psi(depending on the ratio) ,had mine running to ten psi till a few days ago And if you shop around can be cheaper than a tuned ecu. But its limited to what you feel is safe on the fuel system.
enthalpy I dont recall being bad, but I am way out of that loop, if you think you can DIY tune? sohc ecus are the s***, for a hundred bux you could be set, for more you could do realtime ... hybridka rom tuning forum.
no dynos but my dohc at 6ish psi probably make 200 to the wheels. A local guy ran 8:1 at 12psi and made 320whp and had dyno sheets to back it.
