Nissan Maxima 2002 DRL replacement
bodhayanc
Car: 2002 Nissan Maxima GLE
Hi,
I have 2002 Nissan Maxima GLE. One of the Daytime running light is not working. Can anybody tell me the procedure to replace the bulb?
Thanks,Bodhayan.
MinisterofDOOM
Car: 1962 Corvair Monza
1961 Corvair Lakewood
1974 Unimog 404
1997 Pathfinder XE
2005 Lincoln LS8
Former:
1995 Q45t
1993 Maxima GXE
1995 Ranger XL 2.3
1984 Coupe DeVille
Is it a Canadian car? Maxima shouldn't have DRL. Which lamp is it using for DRL?
bodhayanc
This is not a canadian car. I cannot attach images in this forum. So I uploaded the images on picasa. Here is the link http://picasaweb.google.com/bo...02GLE.
bodhayanc
Hi All,
I haven't got any information for my post.
Thanks,Bodhayan
audtatious
http://www.moodym.com/maxima/tech/hid-replace.html
Steps to replace the HID bulb. Hope that helps. If you are talking about the parking light then you can get to that without much problem other than having to move the battery out of the way on the drivers side.
bodhayanc
I was talking about the light above the parking light. Have a look at the images in my previous post. I think it is the DRL, isn't it? Do you think it is the same procedure as replacing the Parking light or the HID bulb?
audtatious
That's the parking light. The Maxima did not come with DRL's.
bodhayanc
So, can you please tell me how to replace that?
audtatious
Above is the passenger side headlight. The yellow arrow points to the parking light and the red points to the turn signal. Reach behind the headlight to replace the bulb. As I stated before, on the drivers side you will have to move the battery out of the way to have easier access. Grab the gray plastic connector with your fingers and twist to remove.
