HOW TO: Clean Climate Control Sensor
Qxxx4
Car: 1999.5 Infiniti QX4
2012 Ford Mustang
was cleaning up the mess the previous owner left in regards to a remote starter, which never worked right so I unplugged the unit when i bought the vehicle. I ended up cleaning the really dusty paneling under there and putting in a better brighter security led, and wired up the security LED from the remote starter that is on the windshield to the same LED. Ended up finding this very dirty sensor
then just simply remove all the connectors, and the hose just pops off
easy, but easily overlooked
pathy1217
Car: 97 Pathfinder LE 4X4
Were you having problems with your climate control or something? Did it make a difference after cleaning it?
Qxxx4
2012 Ford Mustang
just cleaned it, wasnt having any issues nor do i notice a difference but i was there so i figured i might as well clean it
fueler
Car: 2 Nissan's
2 BMW's
what did you clean it with ?
Qxxx4
2012 Ford Mustang
air compressor
CanuckQx4
Car: 2001.5 Infiniti QX4 2WD
were exactly is the temperature sensor?? after you pull all those panels off
ltsnotme
Car: 1996 Pathfinder XE 4WD
CanuckQx4 wrote:were exactly is the temperature sensor?? after you pull all those panels off
Right behind this little grill thing:
fueler
Car: 2 Nissan's
2 BMW's
wow, 2 yrs after reading this thread and I still haven't cleaned mine... lol
i dont use the "AUTO" feature of the climate contol anyways.
CanuckQx4
I dont know where that little grill thing is I dont recall ever seeing it, I guess Ill have to go down and look!!
Towncivilian
Car: 2001.5 Nissan Pathfinder SE 3.5L 2WD A/T
2007 Nissan Altima 2.5L CVT
2012 Nissan Sentra 2.0L CVT Special
2012 Infiniti G37 Sedan 7A/T
It's to the right of the steering wheel. You can barely see it in the lower right corner of this picture:
