Do 510 suspention parts fit on a 620?
1972-1979 Datsun 620 forums. All 620-specific topics and discussion can be found here.
eatroad
Car: 1973 Datsun 620
I am looking at springs and sway bars. I can find them for the 510 but not the 620. Can I use the 510 stuff?
phlebmaster
Car: 1973 240z L26 4spd rip roar and ready to go!
eatroad wrote:I am looking at springs and sway bars. I can find them for the 510 but not the 620. Can I use the 510 stuff?
The 510 has independant rear suspension with coil springs.
The 620 has a solid rear axle and leaf springs.
The answer is not without some serious mods.
eatroad
Thank you. Do they make these parts for the 620? Do you know where I might find some? (Springs and sway bars)
moparvwfreak
Car: 1973 Datusn 620 4 spd(sold), 1973 Datsun 620 5spd, 1993 BMW 325I, various VWs and now a CB7 Accord
early 620s had a front swaybar. later ones i dont think do but were optional. as for springs, no clue. the only springs are the rears. the front is torsion bars.
eatroad
Ok. Thanks. I want to lower the truck slightly. Maybe 1 1/2 inches in the front and 1 in the back. How can I go about lowering it without sacrificing much of the ride quality?
Thanks for your help.
521ofdoom
Car: 1969 Datsun 521 P.U.
Lowering by adjusting the torsion bars in cake in the front, they have a pretty linear rate, so, as long as you keep it off the bumpstops, the spring rate will stay the same, no matter the ride height. in the rear, a set of lowering blocks simply moves the axle, again, no change in spring rate. Same ride. Make sure to have your alignment checked after lowering it, may not need adjustment. I have had good luck with pulling my bars out, moving them one spline lower and re-tensioning them. gives a 1.5" drop or so. and they're still at full tension. Good luck
Return to “Datsun 620”
