ca18detgabby
92 s13 ca18det, 03 G35
lake mary fl
2-10-2007
| « Re: not quit there (zombieslider) | 7:43 PM 8/31/2009 |
your going to shell out for a greddy timing belt but run a volvo FMIC?electric fans use the stock mani, not the turdular(more money you could invest toward a good FMIC setup or even a tune) make sure your harness is all set do you have a good maf? should have your injectors flow tested and cleaned
 extra stuff http://forums.nicoclub.com/zer...s-ect
zombieslider
Suwan Ga
8-31-2009
| « Re: not quit there (zombieslider) | 8:07 PM 8/31/2009 |
are the volvo fmics so horrible, i just like the set up and the fact that its not saying to everyone im turbo. I drive a vert and it seems more practical for it to not get stolen.
ca18detgabby
lake mary fl
2-10-2007
| « Re: not quit there (zombieslider) | 8:09 PM 8/31/2009 |
| Quote, originally posted by zombieslider » | | are the volvo fmics so horrible, i just like the set up and the fact that its not saying to everyone im turbo. I drive a vert and it seems more practical for it to not get stolen. |
dont get me wrong. I drove with a 740 volvo FMIC for almost 2 years solid and was a great cheap alternative. fitment kinda sucked, but we made it work. however, it seemed you were spending alot on things for a more hardcore build....... which a stock volvo intercooler really isnt great for.
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
Yea, ditch that manifold and keep the stocker. I wish I had. Spend that money on the motor and trans mounts or suspension or brakes.
Resident CA Parts Hoarder #2 I think we all know who #1 is...
| Quote, originally posted by themadscientist » | Ask for directions to soapland, bring about Y50000 and don't take your mom. |
zombieslider
Suwan Ga
8-31-2009
| « Re: not quit there (zombieslider) | 8:26 PM 8/31/2009 |
i would rather just replace certain things while the engine is out rather then them messing up later down the road. Idk much about the intercooler set up but i read that it can handle 300hp and im not planning on making anything above that in the future. Thank you for your imput
mbmbmb23
Charlotte NC
8-19-2004
| « Re: not quit there (zombieslider) | 10:04 PM 8/31/2009 |
-Steering rack bushings (suspension techniques makes em for the Z32 and they fit the 240sx and are a fraction the price of the "nismo" S-chassis ones) -Main bearings for the crank -Nismo roller pilot bushing -Z32 throw out bearing -New idle air control valve -New vacuum lines (buy a spool on ebay cheap) -New injector O rings -New thermostat -New O2 sensor -New water temp sensor -Boost and oil pressure gauge -Nismo Fpr and inline liquid filled fuel pressure gauge for underhood -New oil pickup (or check/clean current one) -Magnetic oil drain plug Volvo intercooler is fine if you do it right and dont jerry rig it. The shorter piping (less pressure drop) makes it okay in my book...just dont skimp on the silicone connectors and piping or it will look like a frankenstein junkyard setup. Also have it pressure tested before you mount it.
Good luck!
zombieslider
Suwan Ga
8-31-2009
| « Re: not quit there (zombieslider) | 7:33 AM 9/1/2009 |
alright so it looks like ill just keep the stock manifold and get nismo motor mounts, ive relpaced my steering rack bushings about a month ago with energy susp. Forgot to mention i planned on getting oil/water/boost gauge.what other options are good for a fpr, for instance the megan racing one already has a gauge on it but do i need an adapter for my stock fpr?
zombieslider
Suwan Ga
8-31-2009
| « Re: not quit there (zombieslider) | 8:50 PM 10/6/2009 |
picked up my ca today tomorrow after work im gonna start cleaning it and replacing some stuff i need to get alot of gaskets and still waiting on a timing belt and nismo mounts to come in although the stock ones look perfect. Prolly have pix tomorrow night.
fabio240
S13 with ca18det
district heights maryland
4-3-2008
COMPRESSION TEST THAT S.O.B.
zombieslider
Suwan Ga
8-31-2009
| « Re: (fabio240) | 9:14 PM 10/7/2009 |
didnt do a comp. yet, leak down was like 100 on 1 and 4, 102ish on 2 and 3. Also my camera died when i went to take picks but i pulled the wiring harness, tranny and exhaust manifold/turbo off today. Clutch was almost non existant and flywheel had a lot of burnt spots but its ok i wanted to do the sr clutch n flywheel anyways. Oh and the turbo had massive shaft play back n forth no biggy i have a sr t25 anyways.
zombieslider
Suwan Ga
8-31-2009
| « Re: not quit there (ca18detgabby) | 11:23 AM 10/8/2009 |
rico05
I pwn.
1992 RMS13 w/ CA18DET
Carrollton Texas
6-23-2003
There's a lot of oil spray all over the exhaust side of that block. Makes me worried. Good luck...
SR20DET = 189cc Wasted.
| Quote, originally posted by dickie » | | some hard gheyness in this thread. |
zombieslider
Suwan Ga
8-31-2009
| « Re: (rico05) | 3:39 PM 10/9/2009 |
it seems like the valve cover was leaking on that side of the engine. Progress on it has been slow because im sick going to the doctor tomorrow hopefully i can get some meds and starting cleaning more i got about half of the tranny cleaned and thats all.
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
| « FN-QR | 9:26 PM 10/9/2009 |
Yea, yours leaks from the same place mine does. It's like that square part of the cover doesn't seal and it leaks down.
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (float_6969) | 10:07 AM 10/10/2009 |
yup right there at the back corner, also found a bit of oil in the intake tube the piece directly clamped to the turbo
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (zombieslider) | 3:21 PM 10/10/2009 |
cleaned the tranny today
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (zombieslider) | 9:09 AM 10/14/2009 |
i need to clean the block but basically im waiting on parts to come in and also to get more money so i can buy the rest of what i need, im looking at getting the oem gasket kit is the head gasket good or should i get a felpro?
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
| « FN-QR | 7:15 PM 10/14/2009 |
OEM and Felpro work equally as well. Get whichever is cheaper.
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (float_6969) | 7:48 PM 10/14/2009 |
alright ill just get the whole kit, now i just gotta decide which clutch to get
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
| « FN-QR | 5:50 AM 10/15/2009 |
I'm a SPEC fan, but be aware that the pedal pressure is very light, and the friction point is up near the top of the pedal travel. If you learn how to drive it, you can shift faster than you would with a clutch with a normal friction point.
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (float_6969) | 9:29 AM 10/15/2009 |
ive narrowed it down to either the act heavy duty street/strip or the competition clutch stage 2
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (zombieslider) | 5:31 PM 10/25/2009 |
let the parts hoarding begin. Today i picked up a block with detonation on cylinder #4 and a head with evereything on it minus the wiring harness for 30 bux!!!!!Also painted one of my vc's it looks like im gonna do the exh. cam swap does anybody know how good the ebay cam gears are?
Dattebayo
Jinchurriki
Online
S12 w/ VG30E
DC Metro Area
8-25-2002
I have a new SPEC stage 2 for sale for $200, BTW. I've been trying to find someone with a serious effort to own it, lulz
 FSC = Fu*king Sh*tty CigarettesThe most amazing thing in the world! You have to see it --> www.mostamazingthing.com/holycrap/huge.jpg
ca18detgabby
lake mary fl
2-10-2007
| « Re: (Dattebayo) | 6:42 PM 10/26/2009 |
wow that was a mess.....gl with the build. take pics as you take it apart.
zombieslider
Suwan Ga
8-31-2009
| « Re: (ca18detgabby) | 8:31 PM 10/26/2009 |
i already got a clutch thanks for the offerand as to pix of it apart kinda skipped some parts of that, its pretty much all apart right now replaced the head gasket next steps are timing belt, exh cam swap, port the manifold for the ka throttle body, and put everything back together.
rico05
I pwn.
Carrollton Texas
6-23-2003
I would recomend pulling apart the exhaust side valve cover (there are like 6-8 screws) and sealing the 2 halves. Sounds like progress is coming along nicely.
zombieslider
Suwan Ga
8-31-2009
| « Re: (rico05) | 10:31 AM 10/27/2009 |
thanks, i already pulled it to paint. Progress is slow it seems everytime i plan to work on it something comes up and i dont get very much time to work on it but itll get done.
hnic514
Silvia S13
Montreal Canada
6-25-2007
I would replace every coolant and heater hose since you have it out!
zombieslider
Suwan Ga
8-31-2009
| « Re: (hnic514) | 4:34 PM 10/27/2009 |
ya most def
zombieslider
Suwan Ga
8-31-2009
| « Re: (zombieslider) | 9:12 AM 10/28/2009 |
last night i got the old oil pump off and replaced, also sealed up the oil pan(with new gaskets) and put my timing belt on, today im gonna clean the block and possibly paint it then its replace the hoses that i can and reassmble it all.
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
| « FN-QR | 10:48 AM 10/28/2009 |
Did you say gasket on the oil pan? Was it the cork one that comes with the felpro kit? If so, take it back off and ditch it. It'll leak. Use the end seals and a bead of RTV. Just about everything else leaks.
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (float_6969) | 1:29 PM 10/28/2009 |
i got the nissan oem gasket set so it came with the 2 halfs and i rtved the restp.s. thanks for closing that thread i swear i said it like 3 times
Modified by zombieslider at 1:55 PM 10/28/2009
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
| « FN-QR | 5:23 AM 10/29/2009 |
Ok, cool. I was just checking. I made the mistake of using the cork gasket that came with the felpro kit and it seeped oil. LOL, no prob.
zombieslider
Suwan Ga
8-31-2009
| « Re: FN-QR (float_6969) | 6:22 AM 10/29/2009 |
that sux man i think i read that somewhere but dont remember, also do you know what the measurements on the valve cover bolts are i wanna reaplace them with something else maybe star point bolts anyways painted the block last night ready to put everything back together
T-M
92 200SX (240sx) and 04 Lexus GS300
Hockenheim
4-23-2007
congrats on the progress, but make sure you buy flex turbo lines from frsports.com, it will make your life a lot easier. good luck!
zombieslider
Suwan Ga
8-31-2009
| « Re: (T-M) | 8:12 AM 11/1/2009 |
I was thinking about getting the i-sis ones cuz they are black but is it really that helpful? I cant really justify spending the money because i still need to get a clutch,starter,batter, intercooler piping and brake rotors to get my car on the road .
float_6969
1995 Nissan 240sx
Topeka Kansas
8-26-2002
| « FN-QR | 7:40 PM 11/1/2009 |
It's not impossible with the stock lines, it's just WAY easier with the flex lines.
nissan_guy240
1989 nissan 240sx hatch w/ca18det 2005 nissan sentra SE-R spec V
FARMVILLE va
9-15-2008
float and T-M are giving you some good advice about the lines; with the motor out it is not to bad with the stock lines, but when you need to work on the turbo later. you will hate yourself for not getting the lines. trust me 30mins vs 2.5hrs
180sx build stage 1.6
zombieslider
Suwan Ga
8-31-2009
| « Re: (nissan_guy240) | 2:14 PM 11/4/2009 |
well i got the turbo bolted up and working on the lines tonight, like i said im tight on money right now ill get lines later. Ordered my clutch and im prolly gonna get my starter sat. or sun. after that all im gonna need is a battery and to put this thing in.
| First 1 2 > Last |
