1972 Datsun 510 Wagon
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
Pento240sx
Car: 1995 Nissan 240SX SE, 1981 Datsun 210 Deluxe, 1981 Datsun 810 Maxima Deluxe and 1999 Infiniti Q45t.
So there is a guy which is selling his 510 Wagon in running condition. Little surface rust, 4 speed, and new custom drive shaft. Problems is that shocks need to be replace, the dash is cracked a little, interior is kind of bad. He wants $1700 and to tell the truth I don't know much about the 510 wagons and was wondering if is a good price and general info about the 510 WagonThanks for your time and info
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
rust is the killer, if the chassis is solid it's a good price, the chosk are simple, the wagons got a solid rear axle and evne the trailign arm sedans rear shocks are a smap, one bolt at the bottom one nut at top
the fornt struts aren't that big fo a deal, they use oil dampers origionaloly, you have to remove the strut assy, then take off the prings and get the gland nut off, which can be challanging, if it still got the oil damper you just pull out the gus pour out the oil and out the insert in with the new gland nut, if it's already been converted to inserts you just replace and put it back together
Pento240sx
Thanks
Return to “Datsun 510 / Bluebird”
