need someones help with this
V8 240sx? Sure! If either the chassis OR the engine is non-Nissan (i.e. SR20 in an RX-7 or LS1 in a 240sx), we've done it.
0range_Kouki24O
Car: s13 coupe and s14 sr20det w/2.3 stroker
just wondering what a good compression would be on a 1jz. i went to jdm engine depot today to look at the motors. we did a compression test on 3 motors 1j's and they all had 260 across. shouldnt it be between 160-170??? thats pretty high for a turbo motor
WDRacing
I think the test was bad. 260 is WAY high for an FI motor.
0range_Kouki24O
WDRacing wrote:I think the test was bad. 260 is WAY high for an FI motor.
they did a wet compression test i forgot to mention that. they used atf not regular oil
WDRacing
Well when compression is concerned, adding fluid volume will change the results. So unless you know how much they added you're basically F'd. It's either good or bad...and adding fluid hides what could be bad rings...etc.
FAST-DATSUN
A wet test is only for testing for bad rings. A proper compression test should be done dry with all plugs removed and a good battery and starter, crank the engine for 5-7 rotations on each cylinder recording the compression on the first and last rotation.. then compare all of them they should be with in 10% of each other..
rsagen
Car: 1989 240SX Coupe 5sp SOLD
1989 240SX Hatch auto SOLD
1990 240SX Coupe auto WRECKED
1990 240SX Hatch auto
1990 Jetta Turbodiesel 5sp FEILD BAGGED
1997 Jimmy 4WD
1985 Chev Wrangler
1994 F150 4X4
so it should be between 160-170?
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
rsagen wrote:so it should be between 160-170?
For a factory boosted engine that sounds like good numbers.
Return to “Hybrids”
