Qxxx4
1999.5 Infiniti QX4
Brampton ON
1-6-2008
| « Re: MAF question ??? (JonathanPrem) | 7:17 PM 7/3/2009 |
i wouldnt worry about it if your getting good mileage. im getting really good mileage and my 02's are throwing codes, psht to that. as for the throttle body, maybe they mean just adjusting the cable? does your gas pedal have some play or does it respond as soon as you touch it
JonathanPrem
02 Nissan pathfinder 4WD SE
SCARBOROUGH Ontario
1-12-2009
| « Re: MAF question ??? (Qxxx4) | 7:29 PM 7/3/2009 |
| Quote, originally posted by Qxxx4 » | | i wouldnt worry about it if your getting good mileage. im getting really good mileage and my 02's are throwing codes, psht to that. as for the throttle body, maybe they mean just adjusting the cable? does your gas pedal have some play or does it respond as soon as you touch it |
I think it need adjusting cause i cleaned out the TPS and the idle is bit rough(more then usual)
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (JonathanPrem) | 12:18 AM 7/4/2009 |
Well heres a money saver for yaThe 01 (HAS TO BE 01 im pretty sure) maxima MAF sensor is the exact same MAF, but sells for less than half the price..... stupid stealerships, think it was $110 VS $400+ for the one listed for our car Theres quite a few threads about it if you search and get the part number, youll notice orderring online from Pinnacle Nissan, that the prices are MUCH cheaper than we have at canadian dealerships, and they do actual rate shipping, no gouging. As for throttle body sensors, I wasnt aware we had any, but if they are anything like the throttle position sensors on a honda, you simply need a voltmeter and a spare foot, the TPS (throttle position sensor) has to read a certain voltage at idle, and at wide open throttle (WOT thats my name!!! /stupid plug lol), and you simply loosen its retaining bolts and adjust it, by rotating it, until its in spec, you literally have to move it a cvnt hair to see adjustments, reading its voltage by tapping into its lead wire with your voltmeter Id clear the codes, clean the MAF sensor and IACV body thouroughly, and see whats best from there
Built... Not Bought
JonathanPrem
SCARBOROUGH Ontario
1-12-2009
| « Re: MAF question ??? (JonathanPrem) | 11:55 AM 7/6/2009 |
The MAF senor is $725 from nissan and the maxiam is the same price . Any one now where i can get it cheaper.
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (JonathanPrem) | 1:25 PM 7/6/2009 |
No, its not. Part # 22680-2y001 from pinnacle nissan (trademotion.com) Cost me under $200 canadian shipped Search
Modified by W O T at 1:30 PM 7/6/2009
AJRK
2001 QX4, Ford Explorer Limited, Jaguar XJR
Rancho Mirage, CA and Toronto ON
10-4-2006
| « Re: MAF question ??? (W O T) | 4:15 PM 7/6/2009 |
I had this problem with my MAF start about 2 years ago. First, they cleaned the MAF and reset the computer, and the light stayed off for about 2 months. Then it came back, so I started pricing out MAFs. I was in the US at the time, but the Infiniti dealer wanted $900 to do it, or $700 for the part. I went to a Nissan dealer, and apparently the Maxima MAF is NOT the same, but I bought a Pathfinder one for about $375 and had it installed by a local guy who I trust. At the time, AutoZone had an aftermarket one for $250, but I opted for a Nissan part. I was just at an Infiniti dealer today getting a different code looked after (P0420) and was talking to the technician who I am friendly with about the MAF. He said that now you can get an aftermarket one in the GTA for less than $200. Good luck!
JonathanPrem
SCARBOROUGH Ontario
1-12-2009
| « Re: MAF question ??? (W O T) | 5:18 PM 7/6/2009 |
| Quote, originally posted by W O T » | | No, its not. Part # 22680-2y001 from pinnacle nissan (trademotion.com) Cost me under $200 canadian shipped Search Modified by W O T at 1:30 PM 7/6/2009
| [QUOTE=W O T]No, its not. If you dont mind can you get me the link please. I'm having a hard time finding it.
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (AJRK) | 5:35 PM 7/6/2009 |
| Quote, originally posted by AJRK » | | apparently the Maxima MAF is NOT the same ! | [QUOTE=AJRK]It is, as verified by many members, and Im running one myself. Gimme a sec Ill find the link
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (W O T) | 5:51 PM 7/6/2009 |
Its even cheaper than I remember buying it, click this link, then paste in 22680-2y001 and change make to nissan, wont let me post it directlyhttp://www.trademotion.com/par...id=49 Or $110 from this site http://www.courtesyparts.com/m....html I got mine through pinnacle nissan by calling them, I think i had them 1-2 day it through DHL and there shipping cost was fair. Courtesyparts is a sponsor here though I think, your choice.
JonathanPrem
SCARBOROUGH Ontario
1-12-2009
| « Re: MAF question ??? (W O T) | 5:57 PM 7/6/2009 |
First links doesn't work and the second say 00-01 maximum 3.0L. Should i go head and purchase the second one.Found it http://www.trademotion.com/par...gid=1 buts its 376
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (JonathanPrem) | 5:59 PM 7/6/2009 |
First link works, open it up, and you have to enter the part number in that search box in the middle left, and select the make of the car to nissan, then click search, and the page reloads with the part "volume air flow" right beside it on the right, then you can add it to your cart
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (W O T) | 6:07 PM 7/6/2009 |
$80 dolla, make ya holla
The link that costs $110 comes with the tube aswell (that doesnt fit your car anyways), pinnacle nissans $80 part is just the sensor itself, no tube. If it makes a difference to ya
JonathanPrem
SCARBOROUGH Ontario
1-12-2009
| « Re: MAF question ??? (W O T) | 6:09 PM 7/6/2009 |
Thanks alot WOT . I think nico should make up a messenger so we can talk instantly instead of posting and waiting.
W O T
2001 Infiniti Qx4
Milton on
9-12-2007
| « Re: MAF question ??? (JonathanPrem) | 6:14 PM 7/6/2009 |
lol, yeah, msn and facebook work. I just kept this page open and kept refreshing it while browsing other forums, I hate waiting for answers myself.But doesnt it just suck to know, that any other joe in the world, who had this MAF problem, would simply bring there car into the dealer and eat the $700+ cost?? Like you just saved 700% or something like that, and all it takes to install is 2 freaking screws Blows my mind
JonathanPrem
SCARBOROUGH Ontario
1-12-2009
| « Re: MAF question ??? (W O T) | 7:17 PM 7/6/2009 |
yea i know. I just came out of a big recovery to. My baby was in the garage for 3 f$$ken days and was running bad for 2 weeks and another g for MAF i was like .
