The 300zx axles are too long. I am still working on my setup, 300zx diff and j30 axles. I've got a s13 and if I remember correctly the s13 and s14 have the same diff cover and yeah, you'll need to use the stock ones. Might be a good idea to upgrade you bushings back there. I'm getting these (at the bottom) http://www.splparts.com/main4/...t.htmNismo775 wrote:So im not able to use the 300zx half shafts? The shafts on this are 5 star. its the complete kit. 300zx non turbo lsd(its a 93 to be exact) with the axles. all for $125
True, but I think on my 20+ year old car at least lolrustest86 wrote:around $150 and i would worry about upgrading any bushings unless there wore out. toooo much of a pain in the a$$ for very little gain, trust me
wait so the 300zx and the 240sx have the same gear ratio's, then why would you swap them? for the LSD? so this swap is ideal for 240's with open diff's right? because if you had a 240 with a LSD it would be the same thing as an the 300zx diff...? right? im confused...rustest86 wrote:yes you can use the diff from a j30 the only difference is the gear ratio. same install as the 300zx diff though.
us 240sx- 4.08:1n/a 300zx-4.08:1us j30- 3.96:1
its a taller ratio but you prob never notice.
I can check my local yard and see if they have any j30'sNismo775 wrote:where did u find the 5 star j30 axles?
i cant find them anywhere. google ive searched and nothing
unless im typing in the wrong thing and not finding any
let me know please
