 Cube Head Unit
rev2red
2007 Honda S2000
Dallas TX
1-10-2009
  Cube Head Unit
Does anyone know who makes the head unit for the Cube (with the fosgate system)? I've heard it is made by Clarion but I wanted to confirm. Cite your source if possible.
D3stro
Nissan Silvia K's Ca18det 90,Nissan Sentra Ser SpecV 02,Nissan cube 1.8s 2009 & Nissan Versa 1.8s 20
Joliette QC
11-6-2007
 « Re: Cube Head Unit (rev2red)
Might be possible that it is Clarion. On the 2002-06 Sentra SeR SpecV, the ''Fosgate'' kit was actually made Clarion. Just pull the HU, you should see the brand sticker on it.
Nissan Sentra SeR SpecV 2002 with QR25DE: Apexi WS2-OBX header-AEM CAI-TA 17-No DLR-BS chainless-Faktion SS-RevolutionAutoworks TD-ES MMI-Technafit SS brakes & clutch lines-Unorthodox crank pulley-Tanabe NF210-Nismo RSB
Nissan Silvia K's 90 with CA18DET:Falken Hanabis 17x9 +20 on 4 corner-Exedy Stage 2 clutch-GAB front strut bar-Tom's Motorsport rear strut bar-Tein HA-Megan Racing tension rod-Nismo chrome knob shifter.
Nissan cube 1.8s 2009 with MR18DE Bone stock
Nissan Versa 2008 1.8s with MR18DE girlfirend ride.
miata007
2009 Cube 6sp, 2005 G35 sedan
Sacramento CA
8-11-2005
 « Re: Cube Head Unit (D3stro)
Any recommendation on how to pull the headunit?
Insterested installing an amp and speakers.
007
damian666robin
Baby Cakes
2009 nissan cube
mission hills CA
7-17-2009
 « Re: Cube Head Unit (miata007)
i am swaping my oem stereo for the kenwood i had on my xterra so i will do a DIY post here later.
i even have a feeling that the conections for the xterra will be compatible for the cube since is an 08, that weird antenna conection lol!
2009 nissan cube 1.8S/prefered package
-Rotora big brake kit (4 piston, 13 slotted rotors)
-1st. carbon fiber hood , xxr 962 wheels, falken ziex tires
-nrg hood dampers, nrg radiator cap, megan springs, broadway rear mirror
-nrg pedals, nrg e-brake, kenwood DDX512/bluetooth/i-pod/nav./i-pod dock
-ripple hooks (3 piece), Rockford fosgate woofers P1, Rockford PRIME 500-2
-kicker front components, kenwood rear components, Rockford wiring
smac103
pearl white cube s
denham springs la
7-12-2009
Quote, originally posted by miata007 »
007
i changed my head unit very easily, below the ac controls are the 2 peg hooks, remove the hooks and there are screws, remove them, and then gently pry the ac control cover from the bottom,(mine popped off rather easily (the ac controls stay in place, just the bezel comes off.
once that bezel is off , you can see the two screws on the bottom of the radio bezel, remove the screws and gently pry that bezel off, (mine popped off pretty easily) SEE BELOW*
the rest of the radio install is pretty straightforward, double din radios, such as the pioneer i installed go in with no mods using the original brackets, but you will need both the main harness, and the antenna harness to complete the job.
*VERY IMPORTANT* DO NOT disconnect the air bag light from its connector on the bezel, especially if you turn on the ignition to test the radio (from experience) if youve done this, i can give you the code sequence to clear the "air bag error light" that WILL occur, but just dont do it in the first place
smac103
pearl white cube s
denham springs la
7-12-2009
 « Re: Cube Head Unit (damian666robin)
Quote, originally posted by damian666robin »
Damian: you are correct about the antenna plug , i'd never seen one before, but it is a rectangle plug (about 1" by 1/4") with the antenna lead and a 12 volt lead for the amplified antenna, probably the same one you are describing.
A very experienced local shop had both harnesses in stock for me.
miata007
Sacramento CA
8-11-2005
 « Re: Cube Head Unit (smac103)
Smac,
Thanks for the detailed info on pulling the head unit.
I do haven an extra pioneer double din lying around but do have hi concern with theft if installed in my car.
Will consider putting in a shock sensor to the factory alarm system first.
Any of you plan to do so?
Thanks
007
damian666robin
Baby Cakes
2009 nissan cube
mission hills CA
7-17-2009
sweet man i am glad i keept the radio adaptor from the xterra, i remember back when i first got it no one will have it i looked all over the valley but then the funniest thing....the best buy down the corner from my house had it....haa haaa!
damian666robin
Baby Cakes
2009 nissan cube
mission hills CA
7-17-2009
Smac,
Thanks
007
went thru that twice for not having better alarms so yeah i will upgrade my alarm first before installing good stuff on it he he, do the classic mcdonals or jack in the box papper bag in front of your sound so people wont see it it work all the time back in the days when i had my first cars
» Return to Cube Forum
