nametakennow
Sentra Moderator
'06 MINI Cooper S
Atlanta GA
8-24-2002
First bleed and replace the fluid. If there's no improvement, it's probably the master.
'06 MINI Cooper S - Chili Red/White, stock Sold - '01 Sentra SE (SR20DE) w/pp (VLSD, FSTB), a few mods Sentra Table of Contents *Read it BEFORE posting!* Get your Nissan/Infiniti's FSM here. Need parts? Look here! NEW QR25 forum
Xtream Friction
s2000 with a nissan skyline GTR
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 3:53 AM 7/2/2009 |
is this a new clutch or an old clutch?
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 3:54 AM 7/2/2009 |
did you brake it in ?
Xtream Friction
los angeles ca
7-2-2009
brake in is 500miles regular driveing~
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 3:55 AM 7/2/2009 |
did you bleed the clutch?
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 3:56 AM 7/2/2009 |
if you did not bleed the clutch then that the problem!
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 3:57 AM 7/2/2009 |
did the clutch sound like if it would grind in the tranny?
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 3:58 AM 7/2/2009 |
if so the clutch *throw out bearing* might of grinded through the pressure plate teeth!
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 4:00 AM 7/2/2009 |
or if you resureface the flywheel the might of done it wrong tand took to much off it!
Xtream Friction
los angeles ca
7-2-2009
| « Re: Clutch issues (fiendelico) | 4:01 AM 7/2/2009 |
check thickness of clutch disc? and make sure the offset part is facing the pressure plate not the flywheel...
ProudNissanFreak
1998 Nissan 200sx, 2005 Imaginary WRX Sti
canadian, but in bradenton fl
12-9-2008
| « Re: Clutch issues (Xtream Friction) | 7:47 AM 7/2/2009 |
Wow, way to be a prick trying to get your 10 posts.
ABNRML4U
NISSAN B-13
Tampa FL
4-6-2009
| « Re: Clutch issues (ProudNissanFreak) | 11:21 AM 7/2/2009 |
+1
