Maintenance
KyooX4
Car: 2001 Infiniti QX4 4wd
My QX4 is nearing 110,000 miles. I will be doing an oil change and was wondering what other kind of maintenance I should be doing or if there were parts that needed to be replaced around this time. I'd like to do a full tune up but I don't know what all is involved.Thanks
miamiheat3332
Car: 2002 Nissan Pathfinder SE - 2006 BMW X5 4.8is - 2001 Audi A4 1.8T Quattro Sport
change air filter, spark plugs, if you didnt lube it, get that done, fuel filter, suspension if you never replaced it, at least for me i have to do it, its pretty much crap at 104k. if you tow, rear differential fluid, mabye transmission fluids, those are all ideas i dont know what you did or didnt do.
edit: if you never replaced the rear o2 sensors, even if they dont throw a code, i think they are suppost to be replaced every 80k? dont take me up on the 80k cause im not sure.
korbeano89
Car: 1997 Infiniti QX4
trany fluid and filter, spark plug if needed, there's a zurk fitting to grease up on the drive shaft i think or some where near it, fuel filter, power stearing fluid, check distributor cap and roter, and im sure there's more people will let you know.
Mariach
Car: 2001 Nissan Pathfinder SE
Yea, I just had my front struts and sway bar links replaced, and all fluids changed, belts replaced, filter as well.
It's all about due around that time, but then she will be good as new for the next 40,000km
Buzzman
Car: 2016 Lexus RX 350
2023 Kia Stinger Elite V6 AWD.
korbeano89 wrote:trany fluid and filter, spark plug if needed, there's a zurk fitting to grease up on the drive shaft i think or some where near it, fuel filter, power steering fluid, check distributor cap and rotor, and im sure there's more people will let you know.
If it's a 2001 QX4, then it should have the 3.5 engine. No distributor cap or rotor. Just ignition coils.Agree on the rest though. Spark plugs, fuel filter for sure, if they've never been done.
Mariach wrote:Yea, I just had my front struts and sway bar links replaced, and all fluids changed, belts replaced, filter as well.
How much were the struts? Who did them, dealer or local garage, or DIY?What symptoms were you getting that prompted you to do the struts?I think mine are starting to go, and was wondering what to do about it.
Mariach
I had the dealer do them, but only because he gives me a great deal on everything, since we have been going to him since '98.
It was around $500 for everything up front, compared to what most shops were quoting me, almost $900, I figured it was a good deal, and I don't have time or the mechanical inclination to do it myself.
My biggest indication was a toss up between the leak in the strut, or the persistent knocking and sway I would get every time I hit a bump hahah
W O T
Car: 2001 Infiniti Qx4
Air filter, plugs, coolant flush, clean maf sensor, rotate the tires, check bushings, check brake life, power steering fluid cause its cheap and easy to. All easy maintenance thats DIY, no cost other than purchasing
KyooX4
Thanks everyone for the info!
I just got new tires so I don't need them rotated. I do have an 01, 3.5, so no distributor cap or rotor.
vliou
I hope you've been doing rear LSD fluid changes (if you have it)
KyooX4
How would I know if I have LSD?
W O T
You do have a differential, so youve got diff fluid.
I dont know much about that procedure or service spec to change it, but its a low qt fill, so shouldnt cost you much either.
Do you have a service manual for your car?
SOOOOOOOO Handy
KyooX4
What brand of oil does everyone recommend?
Pwnin O'Brien
Royal Purple (Full Synthetic)
They have every type of oil for your car including engine oil, trans. oil and gear lube. This stuff does cost a pretty penny, but it is proven to add horsepower to a vehicle when all fluids are changed to Royal Purple.
KyooX4
Thanks!
I have a 2001, 3.5 qx4. From what I've read I don't need that special tool for spark plug #6. Correct? My manual makes no mention of it either.
