 Valve solenoid trouble
Skapunk4everr
95' j30
Scottsdale AZ
12-6-2005
Hello all,
I have determined that my Valve solenoid is what is causing all the noise. As I have read, the car sounds like a diesel this part may be the culprit. I would like to try the heavy oil trick, how much of the 20 50 should i add? if this does not work, I suppose ill look into getting it replaced but I would rather not spend the money
Thanks!
P.S.
I live right around the corner from Infiniti of Scottsdale, but they did not show the solenoid being available. Ill stop by there tomorrow and check but I think they run around $100.
Modified by Skapunk4everr at 8:15 PM 6/22/2009
GerryO
1993 J30t
San Jose CA
2-9-2007
 « Re: Valve solenoid trouble (Skapunk4everr)
What worked for me was about 1/2 a quart of full synthetic (you can feel the difference with your fingers) added to the old oil, followed soon after by switching to Castrol Syntec SAE 20W-50 synthetic blend (it was the cheapest synthetic on the shelf at Target at the time).
http://www.castrol.com/liveass...a.pdf
Last weekend I started the car (with 177K miles on it) after it had sat again for a month; no smoke, no valve noise and no leaks.
Make sure that your engine timing is correct too.
1972 Datsun 240Z - non op since 1986
1987 Toyota MR2 - 199K+ and counting
1993 Infiniti J30t - 174K+ and counting
1997 Ford 150 - 87K and counting
2003 Saturn VUE - 112K and counting
Skapunk4everr
95' j30
Scottsdale AZ
12-6-2005
 « Re: Valve solenoid trouble (GerryO)
will do, thanks GerryO
GerryO
1993 J30t
San Jose CA
2-9-2007
Hope it works for you as well as it has for me. My problem seemed to be one sticky/noisy valve lifter, that got progessively worse the longer the car sat waiting for a new water pump, timing belt, etc. Adding the synthetic quieted it in minutes, without ever leaving the driveway. Good luck.
Skapunk4everr
95' j30
Scottsdale AZ
12-6-2005
I added some oil and it is quieting the noise quite well . I think i will ad a little more just for good measure.
Skapunk4everr
95' j30
Scottsdale AZ
12-6-2005
ok well the Oil swap did not fix the problem and I think I need to replace the lifter solenoid. Does anyone know where this is at/ where I can find the procedure in the FSM?
Thanks!
EDIT
I just dug up some info from another search, it could be either
VTC solenoid,
or
fast idle engine solenoid
Ill pull the codes again tonight but there were not any last time I checked.
Thanks for all of your help guys.
Modified by Skapunk4everr at 2:02 PM 7/15/2009
» Return to J30 Forum / M30 Forum
