Skapunk4everr »
https://forums.nicoclub.com/skapunk4everr-u35112.html
Mon Jun 22, 2009 5:00 pm
Hello all,
I have determined that my Valve solenoid is what is causing all the noise. As I have read, the car sounds like a diesel this part may be the culprit. I would like to try the heavy oil trick, how much of the 20 50 should i add? if this does not work, I suppose ill look into getting it replaced but I would rather not spend the money
Thanks!
P.S.
I live right around the corner from Infiniti of Scottsdale, but they did not show the solenoid being available. Ill stop by there tomorrow and check but I think they run around $100.
Modified by Skapunk4everr at 8:15 PM 6/22/2009
